"Blackvibe" V2.2 single ch non Rv non Trem build questions
Discussion in 'Amp Tech Center' started by rosssurf, Feb 19, 2020.
  1. rosssurf
    rosssurf TDPRI Member
    Towson, Md
    Hello all, This would be my first amp build and I am looking build a AB763 style head out of this eyelet board designed by Rob Robinette.
    I am looking to make this "Blackvibe" into a head that has an effect loop. Ideally it will have a transformer that can switch between 4/8/16 ohms. I figure I'll use Classictone transformers unless someone recommends others, but, I don't think I want to spring for a Mercury Magnetics.
    Layout - https://robrobinette.com/images/Guitar/AB763_Models/RR763_BLACKVIBE/RR763_BLACKVIBE_Layout.pdf
    Would this be a good output transformer http://www.classictone.net/40-18006.html
    Where would I integrate/(wire) the effects loop?
    Has anyone tried the Metropolis Zero Loss loop in their build? https://store.metropoulos.net/products/zero-loss-fx-loop-kit
    Thank you in advance.
  2. dan40
    dan40 Tele-Afflicted
    Richmond Va
    That OT will work great in a 6L6 output stage. The Metro Loop is a great unit with an excellent reputation in the Marshall world. I have no experience installing one in the AB763 circuit so i'm afraid that I can't be of much help with that.
  3. rosssurf
    Towson, Md
    Thank you Dan40 for your info~
