Blackvibe PR faceplate
Discussion in 'Shock Brother's DIY Amps' started by Mark the Moose, Nov 29, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Afflicted
    Erie, CO
    Has anybody already had one of these made with the right labels to go in a PR chassis? Seems like if a shop has already set it up it might be cheaper to go through them.
  2. schmee
    schmee Doctor of Teleocity
    Is BV the original spacing on holes etc?
  3. Mark the Moose
    Erie, CO
    It can be used with original spacing, but the verb and trem controls will be mid-presence-master...it would be nice if the faceplate had proper labeling.
  4. schmee
    Ahh, I see what you mean now.
  5. Phrygian77
    Crawfordville, FL
    I can send you a partial template for Front Panel Express. It'll fit the Mojotone and eBay Zachmdhunter PR chassis. It's not cheap to use those guys though. It would probably be close to $70 with shipping for a single panel.
    robrob likes this.
  6. Mark the Moose
    Erie, CO
    Yikes... that’s spendy
  7. Mark the Moose
    Erie, CO
    If a guy had a steel blank like Zach sells with a chassis, could those be effectively polished? If so, it might make more sense to do water slide decals and shoot for something closer to a silver face.
  8. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If you have a template in GIF or PDF or BMP most trophy shops with engravers can cut you a plate. You will need to drill holes etc. Needs to be good quality original.
    robrob and Mark the Moose like this.
  9. trancedental
    trancedental Tele-Meister
    London
    I've done a quick Inkscape program basic "Blackvibe" PR file, in Brownface style with numbers 1-10 to suit that type of knob. Delete the numbers if you want a Blackface FP. :cool:
    Based on the Mojotone PR chassis / FP measurements. :)
    monotone chassis
    18.25 x 1.875
    monotone fp 18 1/4 x 1 15/16
    18.25 x 1.9375
    You can edit it & use it for practice, logos are up to you. Brush Script MT is similar to a certain style! :lol:
    Check all the dimensions BEFORE getting a FP made.
    PM me if you would like a copy, the forum doesn't recognise the .svg file to upload.
    EDIT Added a middle control with master volume & presence if needed, deleted the verb, speed intensity controls.
    Mark the Moose likes this.
