Blackstar ht-1r tube upgrade anyone have experience?
Discussion in 'Glowing Bottle Tube Amp Forum' started by stepvan, Aug 15, 2020.
  1. stepvan
    stepvan Tele-Holic Silver Supporter
    amherst
    So I am thinking about upgrading tubes in my ht-1r combo. The two tubes it is equipped are an eec82 eec83.
    Any suggestions?
  2. Les Paul lover
    Les Paul lover Tele-Holic
    England
    If you want to upgrade that amp, you would probably get better results by changing the speaker - assuming you have the combo.
    It's not a particularly transparent circuit IMO, and why I think valve changes may well deliver underwhelming results.
    wevard and stepvan like this.
  3. stepvan
    amherst
    Thanks, a speaker upgrade was in mind too, but I really do not have to many complaints with the stock one. Any suggestions on a speaker?
  4. VintageSG
    Yorkshire
    JJ ECC802 for the output. It's a long plate ECC82 ( 12AU7 ) and it sounds fantastic as an output valve in tiddler amps.
    Sovtek 12AX7LPS A long plate 12AX7. Combined with the above, it's cream in place of milk in your coffee.
    Before replacing the speaker, try running it without the back on the amp. You may like the sound of an open back combo.
    What changes do you want/expect? A 1x10" cab opens new worlds up. If your Amherst is the UK Amherst, the Gear4Music SubZero 1x10" ( The blue one with the Celestion ) is a great sounding little cab for tiddler amps.
    riga_rig likes this.
  5. Les Paul lover
    England
    Sorry, I don't have any suggestions.
    I myself found the amp totally underwhelming and wouldn't spend an extra penny on it.
    But certainly, the combo speaker fails to cope with dirt and becomes pretty muddy and poorly defined pretty quickly. May be I'm spoilt, I usually play Orange amps between 15 and 50w, and found them just to be miles ahead in terms of sound.
    If it wasn't for my son wanting to keep it, the HT1 would be long gone. I've had an Orange AD5 that was way better in terms of sound (no master volume though....) and will use my AD15 and get better (stellar even) sound at any volume than the HT1 can.
    stepvan likes this.
  6. Abu Twangy
    Abu Twangy Friend of Leo's
    Philly
    I bought my HT-1 for $80 used at a pawn shop with a bad speaker out hack. Since they are hybrid amps I don't think tube swapping will have a major effect on the sound. A bigger speaker like a 10" would be a big upgrade, but requires a new or separate cabinet. Mine sounded way better played through my DRRI's 12" speaker
    My HT-1 got little use for a few years; like the Champion 600s I owned during the same time I just didn't care for the sound. Fortunately I didn't trash it because a couple of years later I needed a low volume amp that I could use in my condo. I use a Boss EQ pedal to get the tone shaping I want. Now even with the stock speaker it can sound pretty good. I have found that it works well with all my other pedals. And now I don't have to use my DRRI as an extension cabinet.
    stepvan likes this.
  7. Cali Dude
    Cali Dude Tele-Holic
    California
    I know that it isn't a popular opinion. However, I have had excellent results when replacing stock preamp tubes with the Gold lion gold pin 12ax7s. No more fizzy overdrive. They get great distortion as well as articulate clean sounds. They cost more than basic preamp tubes. To me, they are worth it.
    stepvan likes this.
  8. wevard
    wevard TDPRI Member
    Switzerland
    I will agree with the speaker change. When I was shopping for that amp, I tried both the combo and the head+cab option. The latter was more open sounding, with better defined highs. From the cabs I tried (1x12) the Orange ppc112 was the one I took home. It brings the best (to me) of this amp.
  9. stepvan
    amherst
    I have been really enjoying this amp as my practice amp. Mine seems tight overdrive wise and not too muddy. Maybe mine w as built on a Wednesday
    Cali Dude likes this.
  10. braveheart
    braveheart Tele-Afflicted
    here,there and everywhere
    preamp :JJ EC83s ... the rest depends on what you want in the powerstage: early saturation,clean h, etc
    I have the HT-dual and the JJs made it much smother,warmer,great harmonics...more organic
    I use it in a VHT Special 6, too..with the same result..
  11. 84GTIRookie
    84GTIRookie TDPRI Member
    USA - Montana
    I just hit purchase on an older Blackstar HT1RH! I plan to plug it into a 1x12 Celestion Greenback cab, and put an EQ pedal in front of the amp.
    QUESTION: The amp uses a ECC83 for preamp, and ECC82 for Power tube. The ECC82 tube is low output. In the past, on other amps, I have changed from ECC82 to ECC81 for a boost. I have a bunch of all three tubes laying around. Anyone ever try that on the Blackstar? Thoughts? Thanks!
    I find that every tube, even if it's the same brand and same model, is way different in terms of gain. It's amazing if you swap out two tubes with the exact same brand and model... it will perform different (I guess due to MFG tolerances?). On all the amps I have, I just keep swapping tubes and trying till I find the ones that have the most snarl. So the question is whether the Blackstar could take a ECC81 in power slot? Thanks.
