Blackguard wiring help needed
Discussion in 'Tele-Technical' started by Opferlord, Jun 18, 2017.
  1. Opferlord
    Opferlord TDPRI Member
    McMurray, Pa
    I am working on a blackguard project and here is what I am trying to do. I am trying to wire the a blackguard with a blend like the wiring diagram above but I would like to do this with a switchcraft on/on slider eliminating position 3 altogether. I have been trying to work this out but I'm having a little trouble. Any help would be appreciated.
  2. Peter Rabbit
    Peter Rabbit Tele-Holic
    Toronto, Ontario, Canada
    What exactly do you want the on/on switch positions to do? It looks like you just want to have the neck and the bridge in position 1 and have the neck alone in position 2. Is this correct?
  3. Opferlord
    McMurray, Pa
    I would like the bridge with the neck blend in position one an neck only in two.
