Yes that PI coupling cap makes a big difference.
It's often a ceramic cap too, which may or may not be the kind of texture you want for your whole amp.
That's an interesting thought, you really think one can hear a difference?It's often a ceramic cap too, which may or may not be the kind of texture you want for your whole amp.
I am no expert by any means and I appreciate the opportunity to learn. My ears hear a difference that I don't think is possible with the inference of the writings you have provided.In this example, the grid leak is 1M and the effective input impedance is 1.8M without NFB.
One thing about caps and changes in amps (or even guitars) is it seems to me it's not readily determined "A/B" ing . But rather playing for some time, different songs, or even for an entire gig or in a band mix that brings things out. Add to that there's the difference of the music room vs a venue. Huge difference! I've had amp builds that I have loved in the music room and took to gig and found nearly unplayable!I am no expert by any means and I appreciate the opportunity to learn. My ears hear a difference that I don't think is possible with the inference of the writings you have provided.
Anyway, I have no empirical data for my observation. Just my ears, and I will throw in @Wally and @schmee 's ears as well. Can the three of us be any good at hearing changes in sub bass frequencies? We are talking about corner frequencies at or below ~43Hz (with your example .001uF, 3.7M) in these Fender amps. When we install a .01uF the corner will be at ~4.3Hz. How do the three of us hear a difference when we intall a .022uF? Ears can deceive so... ?
So running with what you have brung...
The writings suggest a voltage drop of .56V across 1M grid leak 1. It seems the RC filter is acting much like I think it is, just acting as plain old high pass RC filter, letting low frequencies to ground, (or to be cancelled with NFB after it passes through the ~1M).
Am I wrong headed in that thought? Does the impedance from cathode to plate change the RC filter as the writing suggests?
The RC filter doesn't let low frequencies to ground. The capacitor's impedance increases with decreased frequency which alters the voltage divider formed by the capacitor and the input impedance. The increase in capacitor impedance results in a reduction of the voltage at the junction of the capacitor and the resistance.So running with what you have brung...
No. I don't see how the writing suggests anything of the sort.Does the impedance from cathode to plate change the RC filter as the writing suggests?
I am not having a problem with your math. I had a read through the AC LTPI article (again). Thanks for directing me to it.If you don't trust my math, look what Valve Wizard says about the input impedance of an AC LTPI.
I didn't see an answer to this question in the thread. You want an 18/3 SVT cable and a Heyco SR 5N-4 strain relief.Can someone recommend a strain relief and power cable that will fit in the existing hole?
The 18/3 SVT cable is listed as 1/4" OD, isn't that a bit smaller than Fender normal cable OD? I have used 1/4" power cables in Fender Chassis before but they were not tight.I didn't see an answer to this question in the thread. You want an 18/3 SVT cable and a Heyco SR 5N-4 strain relief.
Yes, that is smaller diameter. In my experience, black panel Deluxe and Deluxe Reverb amps, have a smaller chassis cutout for the power cable. The strain relief I mentioned fits that smaller cutout and the SVT cable.The 18/3 SVT cable is listed as 1/4" OD, isn't that a bit smaller than Fender normal cable OD? I have used 1/4" power cables in Fender Chassis before but they were not tight.
Sorry for dropping in so late!That's an interesting thought, you really think one can hear a difference?
