I have this blackface deluxe non-reverb that has not been touched whatsoever so far as I can tell. I don't know if it works, as I haven't tried to turn it on. Original tubes, original transformers, original speaker. The only oddities are a 2A fuse and a missing output transformer mounting screw.
I believe it's an AA763. As it's missing the output tube grid stoppers.
Transformers date to 1963. Chassis is ink stamped 1963 but the imprinted serial number is 1964. The tube chart is torn and missing the date code. The inside of the cabinet is not painted, which I have read is a remnant of the brown era.
I'd like to service this amp into reliable playing condition so I can use it. That being said, I'd like to respect the originality of the amp and not replace parts that don't need to be replaced.
I understand I have to:
Install 3-prong grounded plug. Is there an optimal way to do this with an amp of this vintage? Can someone recommend a strain relief and power cable that will fit in the existing hole?
Replace all electrolytic/filter caps. The schematic shows 3 16uf caps but I'm seeing 4 16uf caps in my amp.
Replace resistors and diode in bias circuit.
What else should I do?
Also what's the best way to clean the corrosive metallic dust off the chassis?
Do I also need to replace the power rail dropping resistors even if they measure good?
