Black Water guitars?
  • Thread starter Danjabellza
Danjabellza
Tacoma, Wa
i stumbled across this tonight in an incredibly upscale pawn shop inside the cosmopolitan hotel in Las Vegas. It's a ($5k)T-style guitar with 1 humbucker, a 3way switch, hipshot jannes bridge, open hipshot locking tuners, ash body with very thin finish. (You can see and feel the grain.) and fanned frets. I've never heard of Black water guitars before. Anyone here know about them?
Lighting was very poor. Sorry for the image quality.
Obsessed
Montana
My best friend plays mostly fan fret guitars and basses. He talked about the Black Water electrics, but I don't know if he ever played one. He flips guitars like I flip hamburgers, so I'll have to ask him.
Danjabellza
Tacoma, Wa
It was well put together. Although I did a quick look at their website and a similar set up only costs about 3,200 vs 5000 at the pawn shop. Must be a custom 1 off.
Danjabellza
Tacoma, Wa
Let me know when they have a MadeInChina line. $3,200?!
Does a fan-fretted guitar cost more to construct that a vanilla guitar?
It does. They have to angle the nut, the bridge, and the frets precisely to ensure good intonation throughout all 6 scale lengths.
With fanned frets or "multi-scale" guitars you Have 6 different scale lengths. It's supposed to improve the sound from string to string while also helping to balance tension somehow.
The one I saw/took pics of is a pretty sharp fan. Some have lesser changes from 1st to 6th string. This one was a 2"+ change in scale.
Unfortunately the gal at the shop didn't know anything about it.
Obsessed
Montana
Just to add, if you want a guitar that intonates on every string at every fret, it must be a fan fret. Yeah, the common guitar is totally compromised design wise, due to ease of building and ease of playing. My buddy went from fan fret guitars to fan fret basses, just because he is very sensitive to tuning. They are very, very expensive.
Don't ever do what I did ... intonate at the 12th fret, then check the intonation at any other fret.:oops: :eek:Umm, yeah, some things are better not to know.;)
BigDaddyLH
Kelowna, British Columbia, Canada
How does CNC work on a fan-fretted neck? I though
How much of that is being done by CNC? I thought the fret and nut slots would be cut by automation, so straight or slanted makes no difference. Then I can't imagine fitting frets and the nut are that different. The fancy individual bridge components of a multiscale guitar may take more effort to mount, though.
Danjabellza
Tacoma, Wa
I imagine there is some of that going on depending on the manufacturer. If I understand, they come in lots of different angles some have drastic changes from one scale to another like this one, and others have very slight fans. Very interesting.
jdbunda
Austin TX
Funny how the brain expects to see things in a certain way. Those pictures still look to me like they were taken through some kind of fun-house filter or weird fish-eye lens - even if you know it's a fan-fret.
ThePhilosopher
Houston
I paid less than $2000 to have this guitar made and sourced the neck and fretboard wood myself. The bridge is comprised of 6 ABM single string bridge saddles (not Hipshot). When I had the guitar the 3-way switch provided a series/split/parallel option. The scale lengths are 25.5" - 28.625" and was designed to be tuned from low F-e in fifths.
I've been trying to hunt this thing down for a while now, but I wouldn't pay anywhere near what they are asking for it.
telemnemonics
Asheville NC
How do you find string bending works?
Bending high strings below the 12th fret, as you increase the tension with the bend, you also lengthen the scale length, so the pitch goes up less that normal.
Then bending above the 12th fret, as you increase the tension with the bend, you also shorten the string length, so the pitch goes up more than normal.
Then same positions but low strings you'd get opposite odd effects.
Seems like the goals of these guitars are more sort of piano precision music oriented and less about the liquid moving pitch mojo of slinky stringed electric guitar.
Or am I just missing the point and need to buy and learn for myself?
Danjabellza
Tacoma, Wa
I found a guitar that you custom ordered? And you've been looking for it for a while? Weird. It's at beauty and Essex in the cosmopolitan hotel in Las Vegas. Or at least it was in June.
telemnemonics
Asheville NC
Well that is pretty strange, though of course this is the internet and there are image search functions available on many devices.
I just figured I was missing the disconnect between two presumably similar but different guitars.
Good thing you didn't buy it (ha ha ha $5k), you don't want to get on the wrong side of blackwater.
ThePhilosopher
Houston
The point is to be able to use smaller gauge strings to maintain the guitar-type tone as you lower the pitch. Bending was fine for me.
I had previously sold the guitar to raise needed funds. I had been looking for it to see if I would ever own it again - it appears not. Aaron at Blackwater only makes custom one-off guitars (I can guarantee this is the same guitar) though I wouldn't give him two pennies today (his business skills are non-existent).
