bit size for neck screw holes in body...?
Discussion in 'Tele Home Depot' started by mgwhit, Aug 24, 2009.
  1. mgwhit
    mgwhit Tele-Holic
    Louisville, KY
    I know I've read here (and elsewhere) that the holes in the body for attaching the neck should be big enough for the screws to pass through without really biting into the wood. The holes on my pine body are a bit small. What size bit would you recommend and how loose can you go?
  2. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    11/64" should give you a clearance hole that's not too sloppy. You want the screw to pass through easily without engaging.
    If it was mine, I'd drill a test hole in a piece of scrap and be certain the fit is good before drilling the body.
  3. mgwhit
    mgwhit Tele-Holic
    Louisville, KY
    Thanks! That's exactly what I'll do.
  4. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    The Terry Downs drawing says 0.166 in. dia. That's awfully close to the 11/64 Ricky D suggested. Probably as close as you can get. Just off by ~0.006 in.
  5. the_utp
    the_utp Tele-Meister
    Santa Barbara, CA
    3/16 has worked alright for me. That translates to .1875 -- larger than the Downs drawing, but not outrageously oversized. Plus, I have a nice brad point bit in 3/16 that I like to use, and that'd be harder to find in a 64th size.
  6. mgwhit
    mgwhit Tele-Holic
    Louisville, KY
    Thanks, everyone. I was looking for the Downs template in the Resources section and hadn't found it. I just did a search for it, found the link and saved a copy.
