Bigsby for Harley Benton TE-80?
Discussion in 'Other T-Types and Partscasters' started by Bluenose, Mar 31, 2020.
  1. Bluenose
    Bluenose TDPRI Member
    Hello everyone, I just bought a Harley Benton TE-80.
    I’m in Canada, and it was still a good buy.
    I used to have a guitar with a bigsby and I really miss it for chord vibrato— I play mainly fingerstyle jazz and love the lifelong challenge of guitar playing.
    The TE-80 has a six-saddle through body fixed bridge, so I’m wondering if anyone knows of some type of bigsby or similar style vibrato unit that can be placed on the guitar.
    the bridge has five screws— tow on top and three on the bottom.
  2. Bluenose
    Alternatively, I could buy the TE-50 and an aftermarket bigsby style vibrato unit, but in this case would the b50 be the style to buy?
    I assume routing of the metal behind the saddle would be required and that is not a big deal
  3. Bluenose
    Third alternative— anyone know of an inexpensive tele
    Kit that comes with a bigsby style vibrato?
    or an inexpensive tele with a bigsby style trem?
  4. Alamo
    Alamo Doctor of Teleocity
    Berlin
    This guy installed a chigsby on his Harley Benton.
  5. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Bigsby B5 model.
  6. Bluenose
    B5 would work with the six saddle through body bridge of the TE-80???
    I don’t see how that would work as the strings would need to extend past each saddle
  7. Lothy
    Lothy TDPRI Member
    Germany
    Greetings,
    installed a B50 on a TE70 last week. The photo is not up-to-date, because I have to move the Bigsby close to the bridge, to get better string tension between the saddles and the vibrato.
    I filed notches behind the saddles, so the strings can easily run torwards over the saddles. The advantage is, you don't have to shim the neck, and leave the original setup.
    The Vibramate string spoiler helps a lot during installation process, because you have to level out all the strings horizontal. The string spacing is more narrow than with the string-through setup.
    Spend the extra 40 bucks for the string spoiler or it will drive you nuts.
    Tuning stability is pretty good (well not Floyd Rose style) with a good nut setup and proper stringing.
    Cheers
    Gerhard
    Alamo likes this.
  8. Lothy
    Lothy TDPRI Member
    Germany
    No, you need a 3 saddles bridge (look at my picture), or a roller bridge. But this will need extra holes to drill + neck shiming.
    Alamo likes this.
