BIG SE Transformers
Discussion in 'Shock Brother's DIY Amps' started by Jammin'John, Feb 24, 2014.
  1. Jammin'John
    Jammin'John Friend of Leo's
    Tug Hill Plateau
    Yea,big,heavy,& expensive.
    Like a nice touring motorcycle.
    I just want to try something different.
    I have the other size amps.
    Some cathode bias,some fixed,all but one push-pull.
    The latest thinking is an amp head that will run either:
    3 x 6v6's
    2 x 6l6's
    1 x KT88
    If that doesn't happen then the next smaller is:
    2 x 6v6's
    1 x 6l6
    1 x KT 66 77 maybe 88 & 90
    JJ
  2. stratavox
    stratavox TDPRI Member
    Pittsburgh, PA
  3. Jammin'John
    Tug Hill Plateau
    SE
    Thanks stratavox.
    Primary impedence is wrong.
    JJ
  4. Jammin'John
    Tug Hill Plateau
    Changed the plan.
    Gonna go with 3 x KT's.
    I one position I will run 2 x 6L6 or KT66 or KT77.
    In the other position I will run one KT88,90, or 120.
    So far this is the transformer.
    PT = 600v CT at 180ma, 6.3v at 4a
    OT = 1250 / 8, 4, 25W, 150ma
    I'm looking for whoever makes the best octal sockets.
    High voltage and high current.
    JJ
  5. Keyser Soze
    Keyser Soze Tele-Holic
    Johnson City, TN
    Don't look at the numbers on either side, look at the ratio of the two.
    That transformer can be wired 5000 to 16
    Which is equivalent to 1250 to 4.
    You could probably still run it with an 8 ohm speaker load as well, but at some loss of peak power output.
  6. Jammin'John
    Tug Hill Plateau
    See above post.
    Different tranny now.
    Heyboer is willing to make anything I want.
    Cheaper than Hammond,more expensive than Edcor.
    I'm looking for the finest sockets for KT120.
    Lotsa HEAT & Voltage.
    JJ
