big box redwood
  • Thread starter Newbcaster
Newbcaster
Gilbert
i bought some remarkably quartersawn, dry as a bone redwood 2x4's from home depot. Is it safe to use for a guitar as in not chemically treated? I cant find a source online to tell m one way or another. I figgered the collective brain trust would know?
Newb
trev333
Coolum Beach,Australia
Take a shaving off one edge with a plane and see if there's a dark edge where anything might be soaked into the fresh cut wood...
We don't have redwood here, I don't know if it's been treated,,,
most treated wood here has a green/blue dye in the mix,,, construction timber usually...
Newbcaster
Gilbert
yeah nothing. i hate assuming im safe. hd website says if something IS pressured treated, but it doesnt say if something ISNT... whats a poor guy to do lol.
Make a guitar I guess.
trev333
yeah, build away.... maybe get some paper masks for sanding....
once you start putting finish on... it will all be sealed up.
Henry
I've found that the finished sizes of timber nominally 2 x 4 are too thin to survive the production process and end up being Tele thickness. Then again there's no rule that says a Tele type guitar has to be any particular thickness. You might end up with a Thinline.
Newbcaster
Gilbert
yeah... 1.5 really. I have some 6 inch redwood finished pieces from HD also... in the nice aisle for hobbies i guess. it's not quite 3/8ths thick but i got it cut in 20 inch lengths and its remarkably flat and straight.
It's gonna be hollow for sure.
Newbcaster
Gilbert
Pick some nice 3/8th lumber and put a top on your redwood.
Looking for a top and a back. I did cut the insides out such i can still get the arm rest... kinda like a tom anderson drop top without all that... oh what is it.. can't place it.. oh yeah.. skill. :p)
fenderchamp
omaha
doit for sure. I used a 2x6 and laminated a piece of 1x6 onto the back. and it turned out to be anything but crap!! The satisfaction I get out of playing guitars that I ...did whatever on..is hard to kind of put into words. Have a ball.
Newbcaster
Gilbert
Well I'm taking the lot of you guys' advice and and building a Redwood hollowed out Coodercaster. Probably gonna have a deep tenon neck joint... with the neck made from a 1.5 inch quartersawn, bone dry piece of redwood 2x4 also. It's 36 inches long. Of course of course it's gonna have a truss rod and carbon/ brass laminate stiffeners and a 3/8ths inch flame maple fretboard.
I have a gfs USA spec'd tremolo with the big brass block. Brass nut. Should be toneful. Valco lap steel pickup and a teisco... and a dimarzio X2N(Middle) just in case...
