Between a tubescreamer and a blues driver there is...?
Discussion in 'The Stomp Box' started by Grateful Ape, Apr 16, 2021.
  1. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon Coast
    I really like my EHX East River Drive. It is a TS-based variant, but seems to fill the niche between fat & fizz.
    Cosmic Cowboy likes this.
  2. loopfinding
    loopfinding Friend of Leo's
    europe endless
    the hot mode on a ts9dx. led clipping and a bigger cap for the low end roll off.
    it was still a little much on the bass for me with a 1uF, so I swapped it with a 100n.
    and now I only use that mode. (but i also get more dirt from the amp than the pedal).
  3. JustABluesGuy
    JustABluesGuy Friend of Leo's
    Somewhere
    I’m glad you mentioned the difference in clipping. After much searching, I finally found that it was one thing that made a huge difference to me.
    Asymmetrical vs symmetrical clipping was the key for me. I find that I much prefer asymmetrical clipping.
    Marc Morfei, Tele-friend and mkdaws32 like this.
  4. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    No. It was mentioned in the first response, Post #2. ;)
  5. mkdaws32
    mkdaws32 Friend of Leo's Gold Supporter
    Moncton, NB Canada
    Technically, I was with the EHX Crayon, which is mostly a Timmy ;)
    D_Malone and Cosmic Cowboy like this.
  6. Cosmic Cowboy
    Cosmic Cowboy Tele-Meister
    New Mexico
    +1
    Marc Morfei and mkdaws32 like this.
  7. D_Malone
    D_Malone Tele-Holic
    Ferndale, MI
    Dang!
    mkdaws32 likes this.
  8. E5RSY
    Georgetown, TX
    Well, it was mentioned; but not specifically recommended. You may get the trophy, after all. :cool:
    mkdaws32 and D_Malone like this.
  9. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Caline Pure Sky. It's a Tim the Enchanter (Timmy) clone, and it sounds pretty good. It's cheap and cheaply made, so no mosh bar gigs!
    The gain knob goes from zero--like there's no pedal in the chain--to mild grind.
  10. lathoto
    lathoto Tele-Meister
    Ohio
    JHS Bonsai. Mr. Clean said, "Low gain midrange has never been so intuitive."
  11. Stiles
    Stiles Tele-Meister Silver Supporter
    Peoples Republic of Austin
    How about this?
  12. igor5
    igor5 Tele-Meister
    Chicago
    Timmy
  13. 41144
    41144 Tele-Afflicted
    Brummagen
    Obvious, Q to me here Greatful-ape is what Gain level are you after... Max, hair, medium ...?
    Personally, providing you're not expecting no noise ( ie you say the BD is fizzy) on a Max gain setting with a KT66 ... Sweet Honey from Mad Professor.
  14. Lies&Distortion
    Lies&Distortion Tele-Afflicted
    SE Michigan
    Rat, SD-1, Klone...
    Blues Driver always sounds good, then my ears get sick of it. It starts to sound like a caricature of what I think a Fender amp sounds like. But I usually am doing that into a Pathfinder, haven't tried with many other amps.
  15. DeepDangler
    DeepDangler Tele-Meister
    Mequon, WI
    Try a Boss OD1X. It’s sonically between the SD1 and OD3 but it uses MDP to create a dynamic response and clarity with some of the best note separation I’ve heard on an OD pedal. More importantly, the EQ has independent bass and treble controls so you can dial in exactly what you need. For my rig, I cut as much bass as possible to tighten things up. Some guys like the fat loose sound.
    Grateful Ape and JustABluesGuy like this.
  16. Grateful Ape
    Grateful Ape Tele-Afflicted
    Need to cut through a dense onstage mix. Sustain and punch without the excessive treble of a BD.
  17. Grateful Ape
    Looks.... expensive....
    Tele-friend likes this.
  18. Dobbin
    Dobbin TDPRI Member
    Upriver
    When I hear fat I hear it's a tone issue, when I hear fizzy I hear it's a gain issue. Its hard to say something is in between two parameters that aren't on the same slider, as it were.
    Have you tried the Waza Blues Driver? It is supposedly less fizzy, right?
    Grateful Ape likes this.
  19. MilwMark
    near Arnold's
    I’m lost. Punching through a dense mix is what a Tube Screamer does best.
    What do you intend “between” a TS and BD to mean?
    If you mean “more mids than a TS,” there is a Way Huge pedal that offers even more mid hump than a TS. The Overrated Special I think.
    DeepDangler likes this.
  20. 41144
    Brummagen
    Again ... more on that really ie horns/keys/lapsteel??? .... but MilwMark hit the nail on the head plus, I'd say, if you need to cut through a mix surely you need treble as from the BD-2?
    I have one of these .... Tech21 Boost-Overdrive ... it can cover a lot of bases the 'Sparkle' control is not dissimilar to a 'Presence' control and you can get a clean boost on top of the overdrive or independently.
    I use mine for heavy 'crunch' (TS style settings) and/or a clean boost alongside a BD-2 for edge of breakup.
    Think you'd have to buy used now or look to something like a Fulltone FullDrive - never owned one so no idea how comparable they are.
    For a budget option - you could alternatively have a look at the Caline Cacti, but again, never tried it.
