Best way to clean Tolex?
Discussion in 'Amp Central Station' started by Boil, Oct 29, 2020.
  1. Boil
    Boil Tele-Holic
    B.C.
    Any recommendations for cleaning Tolex?
    I have never been very pleased with results I have gotten.
    24 track likes this.
  2. Paulie_Boy
    Paulie_Boy Tele-Holic Silver Supporter
    Varies. (Witness Protection)
    Liquid shoe polish makes it look brand new.
    popthree and Bob M like this.
  3. schmee
    I just use Windex for normal cleaning. I will say that some stuff doesn't seem to come off with anything. If black tolex has white scrapes on it from door jamb paint etc, usually Goof Off or something like that on a rag will do it. Dont saturate... just use a bit of the solvent.
  4. Bob M
    Bob M Tele-Afflicted Silver Supporter
    North of Boston
    It (Tolex) is stupid durable. I have used a small amount of paint stripper on it. I’ve used alcohol and paint thinner. Steel wool and Magic Eraser. They all work depending on what you are trying to remove. Once clean shoe polish (as already mentioned)will bring it back as will some of the auto vinyl products-Armorall, etc
  5. Joshiquad
    Joshiquad Tele-Meister
    Wisconsin
    Pledge can work wonders and it keeps dust off, at least for a while.
  6. corliss1
    Lansing, MI
    I don't like to use anything that makes it artificially shiny.
    Windex for most. Fantastik if you have to level up. I have a soft bristle brush that's probably 4"x4" to really scrub it if I need to.
    Deeve and telemnemonics like this.
  7. telemnemonics
    No polishing products!
    No armor all!
    Soap & water!
    A sponge with the 3m green pad side can dull the original slight shine, but a plastic scrub brush can get heavier grime off.
    If no grime just light dish soap applied to a sponge then squeezed out in soapy water so you don't put a big gob of soap on the tolex you then need to keep rinsing off.
    For a bigger project you might remove amp chassis and handles to avoid getting water under steel parts that rust.
    I never use spray cleaners, and never use solvents, but YMMV!
    BTW armor all changes the surface in a way you can't change back from.
    Like putting mink oil on suede.
    ping-ping-clicka and corliss1 like this.
  8. stratisfied
    stratisfied Tele-Meister
    Midwest
    A scrub brush is needed to get down in the grooves. Any trigger spray dleaner will do. Windex, 409, whatever you have will do. Whit paint scrapes from wall need to be scrubbed hard or use goof-Off or other late paint remover. Scrub, rinse, repeat until clean. Spray it with Pledge, Armor-All or other vinyl protectant for a new look.
  9. craigs63
    craigs63 Tele-Holic
    Naperville, IL
    Stealing the thread - what's the best glue (corner of my Champ's covering seems to keep coming undone).
    Boil likes this.
  10. corliss1
    Lansing, MI
    Contact cement. Not the green can that says it's good for the environment, the red can with all the toxic warnings :D
    telemnemonics, craigs63 and King Fan like this.
  11. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    Hand sanitizer + old tooth brush
  12. Lowerleftcoast
    california
    Clean Tolex?
    A beer soaked bar rag has worked just fine.
  13. 24 track
    kamloops bc
    when doing repairs , I always clean the cabs before i return the unit, I use a small scub brush and soapy water wipe immediately then use windex on a wipe to lift the dirt up , and finish it all off with an armourall dash board wipe it makes the cabnet pop .the wipes are not greasey and dry very fast
  14. Boil
    Boil Tele-Holic
    B.C.
    Nooooo! My thread!
  15. ping-ping-clicka
    ping-ping-clicka Friend of Leo's Ad Free Member
    left coast
    now there's a kink, "mink oil on suede". That process is officially known as SUEDE BE GONE.
    I just checked and Toltex IT is not mentioned on my can of HUBERD'S SHOE OIL.
    telemnemonics likes this.
  16. Ringo
    Ringo Poster Extraordinaire Silver Supporter
    Memphis TN
    Simple Green diluted about an ounce or two in a quart spray bottle, soft bristle scrub brush to get in to the grain. Magic Erasers work well too, you can clean grill cloth with it too. As mentioned, tolex amp covering is not naturally shiny. Use some 303 vinyl dressing or Meguiars vinyl protectant if you must use something on it.
  17. INFANT
    INFANT Tele-Holic
    Stoney Creek, Ontario, Canada
    I've always used Fantastic or a similar cleaner on Tolex. Usually spray it on and wipe it off with a cloth. On aggressive Tolex, such as the teal striped Peaveys, I'd used a scrub brush instead of a cloth to get into the craters. Always finish off with some armour all. When I am done, the amp almost looks new.
  18. beyer160
    beyer160 Friend of Leo's
    On Location
    I have an amp with orange tolex that's clearly seen some gigs. I tried 409 and scrubbing the crap out of it, and it didn't make a lot of difference. I saw a YouTube video that recommended Meguiar's convertible top cleaner, so I dropped $7 on a bottle and gave it a whirl. Holy CRAP does this stuff work! A single spray on/scrub with soft bristle brush/wipe off sequence got nearly ALL the black crud off. It didn't seem to change the tolex like Armor All, either. I don't know what's in this stuff, but it works.
    Boil likes this.
  19. Boil
    Boil Tele-Holic
    B.C.
    Hmmm I have some of that for the car, will try it.
