best tool for cutting a pickguard?
Discussion in 'Tele Home Depot' started by TelZilla, Aug 22, 2014.
  1. TelZilla
    TelZilla Friend of Leo's
    Cleveburg, USA
    I have a standard Tele pickguard that I need to alter to fir a Humbucker for the Neck PUP.
    What is the best tool for enlarging the existing hole?
  2. Tinman46
    Tinman46 Tele-Meister
    No
    Router with a plastic cutting bit and template? Might be too high speed and melt the plastic though so I'm not sure. Dremel might work as well.
  3. hemingway
    London, UK
    In my experience about 6 different tools - consisting of whatever works. Files, tiles saws, sandpaper . . .
  4. '59_Standard
    '59_Standard Tele-Holic
    Worldwide
    Thermal Lance.
  5. TelZilla
    Cleveburg, USA
    Not sure what that is, but it sounds AWESOME.
  6. hemingway
    London, UK
    laaaaaazer
  7. fretman_2
    fretman_2 Friend of Leo's
    Mobile, AL
    I've used a regular old router with a pattern following bit with no issues.
  8. TelZilla
    Cleveburg, USA
  9. Mike SS
    Mike SS Poster Extraordinaire
    Nebraska
    I cut one with a coping saw, did some clean up work and beveling with a file and sand paper. Came out pretty good.
  10. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    Router with 45 degree bevel bit or flush trimmer bit. Mount the pickguard material to a template and mount the router to a router table. That way you can adjust the bevel to the amount you want.
  11. '59_Standard
    Worldwide
    And you would not only be the first person to say its awesome, either. ;)
  12. TelZilla
    Cleveburg, USA
    Well, THIS would certainly make a hole in a pickguard:
  13. Ronkirn
    Jacksonville, FL
    bandsaw for roughing it out... plain old carbide router bits for the detail work...
    Ron Kirn
  14. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    It'll make quite a hole in your pocket too :lol:
  15. Telemaestro
    Telemaestro Tele-Meister
    Hartville, Ohio
    Just a ball bearing bit, top or bottom depending on whether you will be using a table mounted router, or a hand held. And you will also need a template, you can buy them, or you could make one yourself.
    -Austin
  16. drmcclainphd
    drmcclainphd Tele-Afflicted
    Abingdon, Virginia
    What do you mean by "best"? And what do you mean by "standard"?
  17. eddie27
    eddie27 Tele-Meister
    Nashville
    I used a band saw then a belt sander with the table at 45* then file and sandpaper to finish. Purty good.
  18. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    Won't work for enlarging the pickup hole.
  19. tvvoodoo
    tvvoodoo Tele-Afflicted
    Western Canada
    Chainsaw is not a good choice.
  20. Robbied_216
    Robbied_216 Tele-Afflicted
    Sydney to L.A.
    For pickup holes I've just used my router with the pattern bit. In fact, I wanted my pick guard cutout to be the same as the pickup route, so I mounted the pick guard as normal and just used a flush trim bit. Came out perfect!
    -Rob
