Best pedal that straddles the line between OD and distortion?
Discussion in 'The Stomp Box' started by JBFatFingers, Aug 19, 2019.
  1. zeedoctour
    zeedoctour Tele-Meister
    I kinda like my BBD Green Screamer. I might have found an original Maxon OD808 ... the pedal that WAS the original Tube Screamer that Ibanez renamed when they self branded it. I hope I get it.
  2. MilwMark
    near Arnold's
    I mean, for 70s style distortion:
    - the OD250 and Rat were there.
    - both also so great overdrive
    - the Distortion + does as well, but to my ear you have to basically crank the level and distortion to get a little above unity. The 250 fixes that to my ear.
    The BD-2 is a great boost, low
    Gain OD and medium OD. No distortion to my ear and goes right from medium OD to fuzz.
    You might actually be seeking a treble booster but that’s a whole other can of worms
  3. zeedoctour
    Picking up my vintage Maxon OD808 tomorrow. Actually excited. What luck !
    beninma likes this.
  4. xgritzx
    xgritzx Tele-Meister
    northern VA
    Blackstone Appliances MOSFET Overdrive
  5. Keefsdad
    Keefsdad Tele-Holic
    Toronto Canada
    I have their Tubescreamer clone, a mini-pedal. it has a bass control and sounds pretty good.
    Skydog1010 likes this.
  6. cowie86
    cowie86 Tele-Meister
    Boss pedals get a lot of praise for being indestructible, but I always think the Rat is the most tank-like pedal out there.
    As they say in Soviet Russia - "You don't play ProCo Rat, ProCo Rat plays you"
  7. johnDH
    johnDH TDPRI Member
    Wilton NSW
    Ive got four, that are higher-gain overdrive or distortion that are good with less gain
    Digitech Hardwire Cm2 and Sc2
    Boss Od1-x
    Guv'nor 2
  8. Guitarteach
    That will spank the Marshall! I have an FD3. Great to push an on the edge amp.
    JBFatFingers likes this.
  9. dsouza
    dsouza TDPRI Member
    Mississauga Ontario CAN
    BOSS OD2.
    The edge from u2 used it on his recording of Until the end of the world. Clearly overdrive bordering on distortion.
    www.youtube.com/u2adrian1000
  10. TeleTex82
    TeleTex82 Friend of Leo's
    San Antone
    I would also look at the LA Lady or Kingmaker from Source Audio. You have the ability to swap stackable drive engines so you can have an OCD and a Rat in one pedal. They sound amazing and the feel and response are top notch.
  11. Skydog1010
    Skydog1010 Tele-Holic Ad Free Member
    North Carolina
    I have it too, as well as an Ibanez TS9, I'm kinda torn between the two sound wise, but I have to admit the Ibanez is easier to work with.
  12. beninma
    beninma Friend of Leo's Silver Supporter
    Massachusetts
    I can't quit my Maxon OD808. For my rig I can't seem to beat it. It's got the right amount of compression and it effortlessly dials in settings that work with either channel of my Orange Amp.
    I can set the OD808 up and do the following without touching the knobs and all will sound good in order of less gain to more gain. With the tone knob set just right it's magic in all configurations, the mid bump just seems to be in just the right spot.
    Clean Channel -> Clean + OD808 -> Dirty Channel -> Dirty Channel + OD808
    The other drive pedal I have right now is a Wampler Tumnus Deluxe. It's a great pedal but it has to be used much more surgically. I find that circuit to be pretty transparent as a boost with my amp. A straight up clean boost setup with the Tumnus will sound good on either channel, but not have much grit on the clean channel, and actually acts like it reduces the compression the amp has. But as the gain on the Tumnus goes up it pushes mids in a spot my amp doesn't like on the clean channel. So the mid control has to get backed down as the gain goes up.. which makes it so there is always one combo that doesn't sound quite right.
    The mid bump can be nasally on my clean channel on the OD808 too.. but the difference is the way it compresses you can dial in a setting where the mid bump isn't nasally until you dig in, but when you dig in the increased compression gets you grit instead of nasal. It makes all the difference.
    zeedoctour likes this.
  13. bsman
    bsman Tele-Afflicted
    Santa Clara
    This is out of left-field, but that's exactly what I use a Tech 21 RK5 for. The SansAmp section gets me a bit of overdrive, which I can push way into the distortion range with the OMG section and boost. By judiciously setting the various levels, I can cover a lot of territory with this little thing.
  14. zeedoctour
    You're almost certainly aware the Maxon OD808 was THE ORIGINAL TUBE SCREAMER ... Ibanez rebranded it after the creator did a marketing deal with the owners of Ibanez for overseas sales distibution. The original TS808's are exactly the same as the OD808. In fact, when you open up an original TS808, it'll be branded in a couple of places on the inside as MAXON.
  15. beninma
    Massachusetts
    Yep, just saying I can't seem to beat it. It's old and boring and yet I haven't tried anything new and fancy that actually seems to be better.
    I think I've owned and sold all these in the past 2 years:
    DOD Looking Glass
    DOD Boneshaker
    OCD v2
    Orange Getaway Driver
    EHX Soul Food
    EWS Brute Drive
    Wampler Tumnus Deluxe (haven't sold this yet)
    The Tubescreamer seems to get talked down so much I waited a long time to try it. Wish I'd gotten it first.
  16. zeedoctour
    I was so happy I got that OD808 for well under a Benjamin. What a find. I had an original 1979 TS808 that I sold because I was in some severe financial badlands. It got a good price but I always regretted doing it. Now I have an original OD808 I can feel not so bad about it. I like the BBD Green Screamer (a Tube Screamer clone) but now I can drive one with the other if I need that kind of thing. Don't know if I'll ever use the amps crunch channel ever again.
  17. karpis
    karpis Tele-Holic
    Lithuania, Vilnius
    One mans overdrive is another’s fuzz. But just try properly biased germanium fuzz face with guitar volume knob adjustments and there might be fuzz, distortion and overdrive in there;)
  18. TeleTex82
    San Antone
  19. j5jarod777
    j5jarod777 Tele-Meister
    marysville
    Actually....RAT is the answer to everything, no disrespect to an OCD, great pedal! But, a Ramble FX Marvel Drive is the best I've ever played.
    TokyoPortrait and 4pickupguy like this.
  20. coloradojeff
    coloradojeff Tele-Holic
    Colorado
    Always been a big fan of the EHX Soul Food....but just got a Wampler Paisley Drive that I really like.
    Straydogger likes this.
