Fender '59 Tweed Bandmaster 3 X 10", Fender '64 Vibroverb 1 X 15".
You may disagree all you want.I disagree. My experience with Twins - and I’ve got a fair amount - is that they sound good even at lower volumes.
The Bright switches are the key. The only thing I don’t like about my ‘68 CDR is that the normal channel lacks the C-10 “bright cap”. The normal channel sounds lifeless to me, at low volumes.Deluxe Reverb is the sound to me, but I grew up listening to Dwight Yoakam albums.
My ‘68 Custom Vibrolux Reverb certainly hits the sounds. It’s got bright switches like a Twin Reverb. I won’t pass up the next good deal on. Twin I see. The Vibrolux is probably all I’ll ever need but I’ve got a sickness.
The Custom series Fenders use what they call the Bassman tone stack, which has a lot more midrange. The midrange cap’ value is different and the result is one I find pleasing; more midrange, but the highs are still there for the taking, if you want them.I mostly use an Engl head and celestion loaded cabs. No, I’m not kidding.
For larger gigs I’ll use a 50 watt Boogie or 100 watt Marshall 2x12 combo. No one ever complains.
I’m a huge fan of (real) country music. Never been much of a fan of Fender amps. I’ll use one in a pinch, if it’s provided backline on a big multi-band bill, or at a festival or something. It’s definitely not the end of the world. But left to my own devices I’d much rather have something more mid-forward.
Gee, thx….You may disagree all you want.
What y’all think? Also what is a “country music amp” in the most generic of terms?
Peavey bandit is all over that one.
Peavey. It’s dependable, inexpensive used and takes any pedal you care to throw at it.
PEAVEY!Peavey Classic 30 or Classic 50
Browns are my favorites as well. Hands down. But they’re prohibitively expensive, even as repops.The Bright switches are the key. The only thing I don’t like about my ‘68 CDR is that the normal channel lacks the C-10 “bright cap”. The normal channel sounds lifeless to me, at low volumes.
The Deluxe Reverb simply lacks the real estate for bright switches, and IMO, this is a significant limitation. Bright switches allow highs, above the cutoff frequency of the bright cap‘ to bypass the volume control, so these caps are more effective at lower volumes. Therein is the conundrum. sometimes you benefit from the bright cap, and other times, it can be too harsh.
I love my ‘68 CDR, but if I had a do-over, I’d go for the Vibrolux version. I may yet install a bright cap on my ‘68 CDR, because as it is, I don’t have much use for the normal channel.
As with all variables, it comes down to a trade off. Some of my favorite amps are the Brownface era, which had more midrange. These were the amps most prominent in the early Surf recordings and, while Surf is usually remembered as being very bright, in reality, those first gen’ Surf recordings had more midrange than was available in the AB 763 “Blackface” era.
When I first joined the Surf Guitar forum, I was under the mistaken assumption that a Blackface Twin was basically the same as a Brownface Showman. I was quickly, and quite politely, disabused of this notion and it was suggested that I listen to Freddie King’s recording of Hideaway as an example of the base sound of a ‘62 Showman.
At least for my purposes, the “Fender sound” is a bit complex. The AB 763 amps were an innovation, but they can fall victim to the icepick effect. The Tweed amps were brilliant and had a very rich tonal spectrum, and the “Brownface” amps were somewhere in between, and in many ways my favorite. But it’s not that simple, because the Super Reverb was an AB 763 with a tone stack that used the same midrange cap‘ value as the “Bassman tone stack”, and these amps were very rich sounding. Horses for courses, I guess.
I’d love to see FMIC come out with a Brownface Showman RI, but I know that I’d never buy one, because I’d be very unlikely to ever actually put it to its proper use. The RI of the ‘63 Vibroverb was probably a better solution, but it didn’t really set the market on fire, either. I think that the Chris Stapleton Princeton is probably about as good as we’re going to get when it comes to a Brownface RI. Of course, it’s not all that powerful, but it is a very good amp, and probably a practical size for many players.Browns are my favorites as well. Hands down. But they’re prohibitively expensive, even as repops.
Happy had a ‘68 Custom Deluxe reverb for about half a year. Couldn’t get the sound out of that I was after at all. And the highs were the biggest problem. It did have a lot more mid than I’m used to hearing from a BF/SF amp, that’s for sure.
My Engl on the clean side has a master volume that works insanely well, and much more of Matchless/Trainwreck thing going on. I have the Boogie and Marshall for really big rooms or stages, but really, they don’t even get in the ballpark for clarity and real chime. But at least they’ve got the mids!
Amen Brother...AmenLet me check my book I carry with me....
Oh yes, here it is...
"And on the 3rd day He built the Twin Reverb."
Lest we not forget. Guitar, Cable, Twin Reverb.
And if you don't think it sounds good at bedroom volumes you're not pickin' right.
I’d love a real 1x12 Vibrolux. Brown Vibrolux IMO is the best amp Fender ever made. I should have bought the one I had a shot at in ‘15. I had the money, and I’m still pissed I chickened out. It was absolutely insane.I’d love to see FMIC come out with a Brownface Showman RI, but I know that I’d never buy one, because I’d be very unlikely to ever actually put it to its proper use. The RI of the ‘63 Vibroverb was probably a better solution, but it didn’t really set the market on fire, either. I think that the Chris Stapleton Princeton is probably about as good as we’re going to get when it comes to a Brownface RI. Of course, it’s not all that powerful, but it is a very good amp, and probably a practical size for many players.
The Matchless amps are another great choice.
