Bending Heavier Gauge Strings
Discussion in 'Tab, Tips, Theory and Technique' started by C.A. Melo, Mar 9, 2017.
  1. C.A. Melo
    C.A. Melo Tele-Meister
    Porterville, CA
    I recently bought a pair of Pyramid Flatwounds (10's) which I've played before but not in a while. I'm not used to the wound "G" string anymore and how heavy it seems. I can bend it but when I do I'm always just short of the note I want to land on. The licks I use the most are Roy Nichols type licks that require bending the "G" string a lot so being able to bend it is important. I was wondering if there are any exercises that could build up my left hand strength while bending or techniques to help bend these heavier gauge strings. Thanks!
  2. rburd2
    rburd2 Tele-Afflicted
    Georgia, US
    As a hack, I'd say just keep rolling and you'll be there in no time. In my experience, you'll adjust automatically. Switching back to guitars with lighter strings may have you overbending, though.
    Edit: autocorrect
  3. Frodebro
    Seattle
    The wound G is actually lighter in tension than a plain G is. The reason it seems harder to bend to pitch is because of the lower tension, so you have to push it farther in order to hit the bent note.
    ebb soul and codamedia like this.
  4. C.A. Melo
    Porterville, CA
    Also I forgot to mention, I'm having the trouble bending the string up (towards the heavy "E" string). I can bend the "G" string down (towards the high "E") with no problems.
  5. C.A. Melo
    Porterville, CA
    Oh wow! I didn't know that! Thanks for the info man. So how do you recommend I push it farther haha?
  6. Frodebro
    Seattle
    Are you using just one finger? If so, get one or two more in there to help with the bending. Makes a huge difference.
  7. C.A. Melo
    Porterville, CA
    Okay cool man I'll definitely keep just trying to bend the heck out of it. Thanks!
  8. C.A. Melo
    Porterville, CA
    No I'm using my ring finger with help from my middle finger.
  9. Frodebro
    Seattle
    I actually switched back to a plain G simply because I just couldn't get comfortable with the lower tension. It intonated better, it blended better volume wise, but bends I have been doing for years kept coming up short and it irritated me.
  10. grooveiron
    grooveiron Tele-Holic
    Calgary, AB
    How does this make sense?
  11. C.A. Melo
    Porterville, CA
    I'm gonna try and get used to it and if it doesn't seem like I'm getting better than I'll probably switch over to a plain "G".
  12. Frodebro
    Seattle
    Because you have the core, and then you have the windings around it to bring it up to the specified diameter. The windings carry very little, if any, of the tension of the string-they would just unravel if they did.
    So you have a plain G, which on a set of tens would be an 018. On a wound string, the core is considerable smaller than that, and therefore requires less tension to reach the same pitch. This is also why it intonates more easily and doesn't stand out as much volume wise.
    RoyBGood, GuildX700 and teleaddicted like this.
  13. rburd2
    Georgia, US
    I'm not sure it does. Whenever I have lower tension (albeit with lighter strings), bends become easier.
  14. C.A. Melo
    Porterville, CA
    So right now I'm playing a size .19 wound "G". If I go to a regular "G" should I stay with .19 or move down to .18? I don't want it to still be hard to bend but I don't want it to be super slinky compared to my other strings.
  15. Frodebro
    Seattle
    Bend are easier, yes, but you have to bend it further to get it up to the same pitch compared to bending a stiffer string. The stiffer string requires a little more effort, but it doesn't have to bend as far to hit the next pitch. It's weird, but it's just basic physics.
    rburd2, teleaddicted and GuildX700 like this.
  16. Frodebro
    Seattle
    Drop to an 18, which is the common size for a standard set of tens.
  17. C.A. Melo
    Porterville, CA
    Okay cool. You don't think that will be too slinky compared to the others?
  18. Frodebro
    Seattle
    No, it will actually be a bit stiffer than what you're currently using.
  19. C.A. Melo
    Porterville, CA
    Okay cool man thanks for all the help and information you shared!
  20. Frodebro
    Seattle
    You're very welcome!
