Whatizitman
EDIT: pdf added.
From what I gather, DSL20 does not use triode mode on the EL34s to power scale. Just low (20w), and really low (10w), plate voltages. There are a few mosfets, but it doesn’t look they are tied to the B+ like with a VVR, either. The PT apparently has several taps. You can see on the left of the schem the two separate rectifiers that switch to the output B+, screens, and PI.
A marshallforum thread a while back the OP measured pretty low voltages on the EL34 plates, in full and low modes.
https://www.marshallforum.com/threads/50w-ot-in-a-20w-marshall-dsl.114100/page-3
Some googling brought up some posts here and there of amp builders that have made low voltage EL34 builds, so I guess it’s possible. So my question is about OT primary impedance. Doesn’t that change with voltage? Does it matter enough to compensate somewhere? I can’t decipher anything in the circuit to indicate that.
As a sidenote, is it possible the OT has an extra tap? 4ohm would be really, really nice. Not a good pic. But it’s the green wire.
