Behringer Gx-210 mod ideas?
Discussion in 'Amp Central Station' started by TheBadHombre, May 15, 2020.
  1. TheBadHombre
    TheBadHombre TDPRI Member
    WA
    I apologize for my noob-ish understanding of how amps work but here goes...
    So I have a Gx-210 ultratwin with two Jensen JCH 10/35s in it. It's solid state. it has a nice clean sound that I like, and I run my amps clean anyway so no problem. However, it sounds kinda stale and plastic-y being solid state and all; so my question is this:
    If this was your only amp, and you had to make is sound as good as possible with only 50 bucks, what would you change?
    PS. I run a nice modeler floor unit, so if it comes down to it, I'd like to be able to bypass the amp entirely and use it as a cab. based on what you can see in these pictures, would I need to add a jack to do that, or can I do it as is? Again sorry for the amateur hour happening up in here ;) Thanks!!!!
    Here's some pics of it from a reverb listing since I don't have it with me to take more upclose pics of:
    https://reverb.com/item/20917333-behringer-gx210
  2. dlew919
    dlew919 Doctor of Teleocity
    Sydney
    You should be able to run the pedal as a cab. Straight in to the amp.
    You can buy me a present with the 50. ;)
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If the amp has fx send and receive you should be run send-effects unit-return and use one or more amp models.
    zosofan likes this.
  4. hunkydory
    hunkydory NEW MEMBER!
    Paris
    Would be great to have your feedback on this, I have the same amp and I'm also looking to make it sound nicer. Let me know how it works out for you.
    I heard the Harley Benton American True Tone pedal is great for around 30$
  5. hunkydory
    Paris
    what do you mean by running the pedal as a cabinet?
  6. dlew919
    Sydney
    Ssentislly plugging it into a speaker not an amp.
    Sent from my iPad using Tapatalk
    hunkydory likes this.
  7. VintageSG
    Yorkshire
    What would I change on it?, nothing. The Jensen speakers it comes with are fine speakers. The power amp stage is a good unit. Use your floor modeller as the pre-amp and the Behringer as the power amp. If your modeller has stereo outputs, you're set. You need to get the signal from your modeller to the slave inputs on the rear. Two normal guitar signal cables will do the job. If it's a mono modeller, a 'Y' cable or splitter is needed.
    You can't just connect a signal pedal to the speakers. They need an amplifier, and the Behringer provides that. What's the modeller by the way?
    Using the slave inputs bypasses the pre-amp entirely. If your modeller doesn't feature a level control, you may want to use the mono out on the modeller to insert return ( normally referred to as FX return, but not in this case )
    I've attached the manual which explains it a bit better.
