Before I do something I might regret
Discussion in 'Amp Central Station' started by Clive Hugh, Oct 10, 2019.
  1. Clive Hugh
    Clive Hugh Tele-Afflicted
    Western Australia
    one of the lugs on my speaker box has come off a couple of times, before I go and solder it on is there any reason I should not do so?
  2. Tonetele
    South Australia
    Yeah. Buy a cheap non working speaker for $1, take lug off, connect it to your speaker wire and plug it in.
    I got a champ where somebody had stolen the speaker, I had on. So I got the amp for free, screwed the speaker into the baffle and gave it to my son. Works fine.
  3. bftfender
    bftfender Friend of Leo's
    York PA
    crimp it a lil tighter
  4. Axis29
    Beaumont, CA
    Only reason might be that you want to change speakers later in a rush. Even soldered, a little heat and it comes right off.
    I keep threatening to do this to all of my amps... But, I'm lazy.
    BobbyZ likes this.
  5. Clive Hugh
    Western Australia
    At my age I’m unlikely to change speakers even if one dies so I will solder it and it’s next owner can as you say easily unsolder.
    Axis29 likes this.
  6. Les Paul lover
    Les Paul lover Tele-Holic
    England
    No reason really.
    These clip on connectors can be real liabilities. They aren't robust, they can corrode/oxydate and stop making enough contact and fail.... which could kill your output transformer.
    Just a word of advice, when soldering it, make sure you place some cardboard or similar to protect the speaker cone where you are doing the soldering.
    The last thing you want to do is drop so hot solder on your speaker cone!!!!
    JustABluesGuy, Clive Hugh and Tim S like this.
  7. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Clean up the metal, use additional flux (sparingly) then apply leaded solder. It’ll be way better than a crimp.
