Been sticking it to me for their double stick tape
Discussion in 'Tele Home Depot' started by wadeeinkauf, Oct 18, 2020.
  1. wadeeinkauf
    wadeeinkauf Tele-Holic
    Monterey CA
    I use a lot of StewMac’s double sided tape. I use it to hold my template to my body and neck when routing. It is great for building a template on the fly for a one time job. I use it to tape sandpaper to my radius beam. Tape sandpaper to my fret leveling beam (scrap granite from my local counter shop). But I hate the price StewMac charges. I have been looking a long time to find a cheaper source for this tape. I found one on ebay so I wanted to share in case others have been looking for an alternate source as well. I just bought it and I can not tell the difference between the two….Except the price. The replacement is called 3M X-Series General Purpose Transfer Tape XG2105, 2 in x 60 yd. The cost is $9.85 a roll. StewMac’s double stick tape is $34.58 a roll.
  2. MLHull
    MLHull TDPRI Member
    TX
    StewMac has some specialty and hard to find items. Unfortunatly they price all items as if they were the sole source. This is a good example of that.
    crazydave911 and wadeeinkauf like this.
  3. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Thanks for the tip. I also go thru this stuff quite frequently.
  4. Steve Holt
    Steve Holt Tele-Afflicted
    Kansas
    wadeeinkauf likes this.
  5. Peegoo
    Peegoo Poster Extraordinaire
    Yonder
    For my sanding beams and blocks I make my own double-stick tape. Here's how:
    Apply a strip of blue painter's tape on the sanding beam. Lay a matching width of blue tape on the back of your sandpaper of choice. With the sandpaper face down on a clean flat surface, lay a thin bead of CA down the center of the blue tape on the sandpaper. Place the sanding beam tape-side down on the blue tape on the sandpaper. Lean on the beam for about 20 seconds while the CA kicks. That's all there is to it.
    You can peel the strip of sandpaper off the beam because the tape releases from the beam. If you're careful about how you store these strips (the side of a refrigerator is good), you can make up these strips in several grits and always have what you need, ready to go.
  6. Steve Holt
    Kansas
    So I did some math, and the rolls I buy are only 36 feet compared to the 108 foot rolls stewmac is offering. So the price difference is 27 dollars versus 35 dollars.
    crazydave911 likes this.
  7. wadeeinkauf
    Monterey CA
    The tape I referenced is 2 in x 60 yd which is the same size and length as the Stewmac tape. $9.85 compared to Stewmac's $34.58. And I did not mention the ebay vendor ships free Stewmac does not.
    Wade
    crazydave911 and Peegoo like this.
  8. 017_017
    017_017 Friend of Leo's
    Earth
    Be weary. Stewart-MacDonald have suposedly changed suppliers and no longer sell the 3M version. I had a roll of the 3M tape years ago and it was the best double sided tape.
  9. wadeeinkauf
    Monterey CA
    I could see no difference between the two actual tapes. I did notice that the backing piece on the Stewmac tape was thicker. I notice no difference between the two tapes on how easy it was to remove the backing piece. On the Stewmac tape when it sets in the shop for a few months it does get more difficult to separate the backing. I would think that you would have the same problem or maybe even a little more problem with the 3M tape since the backing is thinner.
    Here is another thing. I just checked my previous order of this tape in 2019 from Stewmac. The price was $17.75. Todays price is $34.58. I just noticed as you pointed out that this is a new product number so it looks like this is a new Stewmac replacement for what we have been buying from them in the past. I read a comment about the product on the Stewmac website that said the new Stewmac tape is thinner than the 3M tape. This would be be a real problem for me. As it is I have to double or sometimes triple the layers of tape to get a good hold between a template and the working piece. I use a glue clamp to press them together then remove the clamp. I have had tape/template slip while routing in the beginning of my learning curve so I take no chances now.
    In fairness to Stewmac looks like this is a replacement/upgraded product. This may be a better tape for some users needs. Not for my use especially at this new price.
  10. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    Been doing this method and it works brilliantly.
  11. Peegoo
    Yonder
    I've found a really good way to stick templates to wood for routing is little pieces of double-stick carpet tape. A little goes a long way. This stuff is thick like duct tape and it takes just a few small 1/2" x 1/2" pieces to securely hold a template in place. It also provides a small gap that allows you to fit a putty knife between the template and the workpiece to release the two from each other.
    The good stuff is like gaffer tape: unlike duct tape it completely peels off, leaving no adhesive residue.
    Most every hardware shop/Hopeless Despot/Lowe's has this stuff in stock. Here it is on Amazon.
    https://www.amazon.com/dp/B0141L81GS/
    This stuff is not ideal for fretwork sanding beams because it is a bit spongy--which can be imprecise and affect the accuracy of your fret leveling.
    But it's great for sanding beams used on wood surfaces.
    crazydave911 and SRHmusic like this.
  12. wadeeinkauf
    Monterey CA
    I'll give this a try. My only experience with carpet tape was many years ago was it was very gooie and made a mess when it got warm.
  13. Peegoo
    Yonder
    The modern carpet tape is way better than the old-style stuff.
    Unrelated: You're in Monterey CA? I lived in Pacific Grove between 1984 and 1985. LOVED it! Great surf, great golf, great music, great food, and the Dream ("Pillow") Theater down on Cannery Row was a weekly adventure :twisted:
  14. wadeeinkauf
    Monterey CA
    Thank you for loving this area....See California is not so bad. Having been lucky to have seen a lot of the world I have never seen anywhere that can compare to Yellowstone in Wyoming. In so many ways it is a national treasure.
    Peegoo and crazydave911 like this.
  15. crazydave911
    East Tennessee
    Most feelings on California from me at least are centered on stupid laws and the LA area,the only place I've ever been. My feeling was begging God not to flush that toilet bowl until I was gone lol.
    To be fair however, I've met some of the finest people I know here that live in California. Not all of Persia was Babylon either :D
    Dave
    Peegoo and wadeeinkauf like this.
