BBE Green Screamer problems
Discussion in 'The Stomp Box' started by rwfelton, Oct 4, 2013.
  1. rwfelton
    rwfelton TDPRI Member
    Baytown, Texas
    the green screamer has an awesome tone. i depend on it for everything. i even like it more than my old ts9 (which i no longer have). i only have one issue. it seems the bypass switch wants to work sometimes and sometimes it doesn't. when i step on the switch sometimes it kills the sound completely. whether it is turning it off or on i will lose all sound. i opened it up and it seems that the connection to the switch seems pretty sturdy. i don't see any abnormal signs of wear or anything. any suggestions on fixing it or should i just go buy another one? does anyone know of anybody in the houston area that works on pedals? thanks in advance for any help you can give....
  2. rwfelton
    Baytown, Texas
    300+ views and no replies?
    that seems like a lot of views with no replies?
  3. soulgeezer
    soulgeezer Poster Extraordinaire
    Sinatra's World
    It seems pretty straightforward -- The switch has gone bad. This is generally an easy fix for anybody who can solder (I can't!). Just get a new switch of the same type (DPDT or 3PDT, whatever is in there; Small Bear Electronics carries them and they're really cheap) and replace the one that's gone bad. Boom, you're done!
  4. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    I agree with the -geezer. Easy fix. That's why God created modular construction. No need for a pedal specialist; your favorite amp repairman should be able to do it for you.
    Good luck.
    Scott
  5. FenderGuy53
    FenderGuy53 Poster Extraordinaire
    Marion, NC
    There's a couple of them on Ebay RIGHT NOW for $50/Best Offer!
    Just sayin'...
  6. soulgeezer
    Sinatra's World
  7. soulgeezer
    Sinatra's World
    You don't even need an amp repairman -- Anybody who solders well will be able to do it, no problem. Just attach the wires to the solder points on the new switch in exactly the same way that they are on the current switch. Easy peasy, lemon squeezy!
  8. 52BIGSBY
    52BIGSBY Tele-Meister
    Emsworth UK
    Take a photo or make a sketch prior to removal.
    Richard.
  9. soulgeezer
    Sinatra's World
    I think all the wires in the Green Screamer are white. So, I'd suggest using little pieces of masking tape and number them. It's just easier than getting confused!
  10. rwfelton
    Baytown, Texas
    now that is what i am talking about. some help!!!! thanks guys!!!
  11. rwfelton
    Baytown, Texas
    i think a $5 switch sounds better. i have since purchased the EHX Glove OD. this thing is a monster. i also have some questions on a small amp that i just got that sounds amazing. i have questions over a cab for it. anyone feel like getting on that subject?
  12. E5RSY
    Georgetown, TX
    Give the question its due...start a new thread for it in Amp Central Station. Better results guaranteed.
  13. rwfelton
    Baytown, Texas
    thanks fixing to post it now. i'm new to forums so it may take me a bit to get used to things...
  14. guitarzan13
    guitarzan13 Friend of Leo's
    LaGrange, GA
    I replaced the one in my Boosta Grande.... Took about 10 minutes
  15. Paul in Colorado
    R.I.P. 2019
    I also have a Green Screamer. No problems so far. I especially like it with a lap steel.
  16. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    If you can't handle fixing it yourself, contact BBE support, they are very quick to fix pedals and get them back to you, and they have fixed two of my pedals for free. Great customer service.
    Al
  17. rwfelton
    Baytown, Texas
    thanks. that sounds like the best idea.
