Len058
I'm building Rob's EF80 LPT Bassman micro with a few tweaks. I want a switchable cathode on the V1b, so I can switch to a more Marshall style. I also like the 4 input principle. With an AB-switch pedal I can go between treble and normal, or I can use a jumper between the channels, like my heroes. The switch will decouple the shared 820ohm and 250uf to V1b and hook a 2,2K and a .68uF to the V1b cathode. That should get it more into JTM superlead territory.
I've already made the turretboard and placed almost all components on it. But recently I've been messing with my Champ micro and found that I botched the layout and other things. There was a strange oscillation because the wiring is sloppy and the wires have to be too long. I fixed some of the issues but it's not the way I'd like.
Moving on I decided to really pay attention to detail with this build. I already made a kit amp, changed the EL84's to EF80, and that went fine. So I know I can do it.
I'm using a JTM chassis and before I drill the holes I want to be sure that there are no obvious mistakes in the layout that can cause extra hum, noise or oscillation.
The first Idea: The OT next to the choke, close to the filter caps and choke so there's a short run of wires between the B+ node and the tubes.
Option 2: The OT is in between the output tubes and the pre-amp tubes. The OT is further away from the choke and the PT. Maybe it's easier to manage the transformer spaghetti and there will be less interference of the AC stuff.
Idea's comments? Any help would be appreciated!
Lennert
Lennert
