There was another thread puzzling out this resistor value, but it was from a while back and the consensus was basically "@robrob did this for a reason". I am trying to figure out why @robrob chose a 15K NFB resistor for his Bassman Micro designs.
In his 5F6A Switched NFB Mod page, he discussed that the original 5F6A featured a 27K NFB resistor, and the fact that:
In that same page, he also provides a conversion factor for amps featuring speaker taps other than 2 ohm, and the JTM45 equivalent NFB resistor for 8 ohm would be 20K. As such, it makes sense that in his Deluxe Micro Mod design, the NFB resistor for the JTM45 setting is 22K (close enough to 20k.)
What has me puzzled is why the Bassman Micro NFB resistor is specced out to 15K. Why not 56K???
I plan to include a 3-Way NFB selector in my Bassman Micro build - that's why I'm trying to understand and sort this out.
"If your 5F6A feedback is tapped off an 8 ohm speaker output like mine then your 5F6A feedback resistor should be 56k to give the same amount of feedback as the original 5F6A's 2 ohm output with a 27k feedback resistor. You should use a JTM45 equivalent resistor of 20k."
