Bassman Micro/Hammond 125B OT 16 ohm hookup question.
Discussion in 'Shock Brother's DIY Amps' started by Bitsleftover, Feb 27, 2020.
  1. Bitsleftover
    Bitsleftover Tele-Meister
    Cheshire UK
    Hi, Im planning my bassman micro build and I’d like to add either a speaker impedance selector or multiple jacks for 8&16 ohm speakers.
    What is the best way to attack this?
    Ive looked into it but don’t have the confidence to jump in without asking you guys to double check first if that’s ok?
    The Hammond data sheet doesn’t specify 16 ohms, the closest is 15ohms.
    15 ohms output would require connecting lugs 1&4 to give 21.5K, or lugs 4&6 to give 24K(15ohms)
    (Rob specifies 22.4k for 8ohm speaker @ lugs 2&4)
    Is that close enough?
    To hook up would I just connect both output jack tips to lug 4, then one jacks sleeve to jack 2 and the other jack sleeve to 1 or 6 (depending on the answer to above)?
    As always, thank you for your time and patience with my noob questions.
    Cheers
    Mick
    Sent from my iPad using Tapatalk
  2. Bitsleftover
    Cheshire UK
  3. dan40
    dan40 Tele-Afflicted
    Richmond Va
    If I remember correctly, you can only hook up one speaker tap with that OT. It does not allow the use of both 8 and 16 ohm options unless you rewire for different plate loads.
    I ended up using this OT in my Micro build that allows for multiple speaker taps without changing the plate load. It sounds great in my build and many other members here have reported good results with this brand.
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=164068571385
    https://www.musicalpowersupplies.com/products/
    Bitsleftover likes this.
  4. Bitsleftover
    Cheshire UK
    Thank you Dan, I’ve already got the Hammond so I’ll stick with that I think.
    dan40 likes this.
  5. robrob
    United States
    You need to use the #4 wire for the sleeve (ground) for the two jacks, then the other two wires to the jack tips. You can't use a shorting jack for either speaker jack.
  6. dan40
    Richmond Va
    @robrob ...will that OT allow the use of both the 8 and 16 ohm taps while still keeping the desired 22k plate load?
  7. Bitsleftover
    Cheshire UK
    Brilliant!
    Thank you sir. Much appreciated.
    Mick
  8. Meteorman
    Meteorman Tele-Holic
    State College PA
    Since I'm almost at this point in my build, I'll jump in for some clarity - on the 125B OT, are the secondaries interchangeable at the output jack ? Or is there some polarity to worry about ?
  9. robrob
    United States
    No polarity to worry about.
    Be sure and use the 8 ohm jack tip for the NFB source.
    Meteorman likes this.
  10. robrob
    United States
    Yes, when wired as I describe above.
    dan40 likes this.
