Hyakuya
Hi all
Because my Bassman Micro isn't broken and works wonderfully I thought I would make some changes to it so fixed bias is the plan for no other reason than it's a learning curve and I enjoy it.
I put together a circuit to adjust the bias following the information @robrob kindly provides:
Top left. HV tap from the PT and a couple of Bourns trim pots connected to the 56K grid leak resistors on the right of the image.
Also, as this was in the back of my mind when I built the amp I have bias measuring jacks installed already:
With cathode bias (fixed bias circuit disconnected) in place I measured one of the EF80's as follows:
Plate v (pin 7): 287
Cathode v (pin 1): 4.4
Plate to cathode v: 282.6
Plate current mA: 6.7
Using Robs Tube Bias Calc:
Plate disspation W: 1.9
Plate dissipation %: 75.7
A little on the cool side....
So I connected up the fixed bias circuit and bypassed the cathode resitor then wound up the trim pots to max resistance and powered up.
The plate current on the measuring jacks got to 24mA before I turned it off.... works out at about 270% dissipation if the plate and cathode voltages have remained the same which I think is a little on the hot side. The EF80's were certainly glowing....
From Robs website:
"The 27k bias resistor sets the maximum hot bias. If at full clockwise pot movement (max hot bias) you still need to bias hotter then reduce the value of the 27k resistor--try 24k or 20k. If at full counter-clockwise pot movement (min cool bias) you need to bias cooler then increase the value of the 27k resistor to 30k or 36k."
So I'm going to increase the 27K resistor and try again...
From Robs website:
