Bassman Micro "Artificial 6.3v Center Tap Only if needed"
Discussion in 'Shock Brother's DIY Amps' started by subgenius_one, Oct 18, 2020 at 10:21 AM.
  1. subgenius_one
    subgenius_one TDPRI Member
    On the Bassman Micro LTP layout diagram you find the quote above on v4 Power Tube. It also shows a 6.3v center tap connected to the Power Tube Cathode resistor as well as 2 100 ohm resistors on the power tube.
    I do not find the 2 100 ohm resistors on the schematic or the 6.3v center tap on the PT on the schematic.
    I am using the recommended Hammond 270 AX, but I am unsure of which components apply to this part of the circuit for me.
    What should I include in the circuit? Thanks in advance.
  2. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    sds1 likes this.
  3. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    To be clear, there is no filament center tap on the 270AX, therefore you'll need the artificial CT. @Tom Kamphuys shared the schematic as it applies to you.
  4. subgenius_one
    Thanks! I see it now.... (that you've shown it to me).... ;)
  5. robrob
    United States
    If your power transformer has a 6.3v center tap then I recommend you use it. If it doesn't then add an artificial center tap.
