Bass Roll Off for Dummies
Discussion in 'Tele-Technical' started by closedmri, Sep 24, 2020.
  1. closedmri
    closedmri TDPRI Member
    Chicago
    I’m thinking of replacing the traditional tone knob on a new tele build in working on with a passive bass roll off rather than treble. I’ve found that I can use a linear taper pot on the volume to roll back the amount of highs I need from 10-4, and then it acts like a volume pot from 4-0.
    Does anyone have any recommendations for how to convert a traditional pot into a bass roll off as opposed to a treble roll off? I’ve read some stuff about using 1meg pots but that would change the overall impedance of the circuit would it not? I would like to use the traditional 250k pots and replace the capacitor with something that will roll off lows rather than highs if possible.
    Thanks for any advice!
    Boreas likes this.
  2. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    I did this mod on my Les Paul. You could do something similar.
  3. SuprHtr
    SuprHtr Tele-Holic Silver Supporter
    Rocket City
    A quick edit yields this, since you're looking to get rid of treble cut and stay with two pots. Note that bass cut is produced by placing a capacitor in series in the signal path, instead of using it to send treble to ground via a parallel path. If you're using single-coil pick-ups, disregard the 500K pot recommendation and stay with 250K. I can't vouch for how this will sound, and I'd be prepared to try all of the caps listed to see what works. Capacitors are cheap...
    Digital Larry likes this.
  4. closedmri
    Chicago
    Wow that looks like it will be relatively easy. I should have those value caps lying around from a kit I got with all kinds of values. Makes perfect sense, I wonder how I‘ll screw it up! Thanks for the replies. Is there a website or software available to draft up diagrams like the ones you guys shared or do most people just use image editing software?
  5. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    I use a BOSS EQ-200 for tone shaping. With 4 memories, I have presets stored for all my needs. Bass, treble, or both can be rolled off. I can boost mid range or use the pedal as a clean boost and boost everything. I use the EQ-200 for tone shaping with all of my guitars. I use it to eliminate ice pick from single coils, increase clarity with humbuckers, and make my Telecaster richer sounding or twangier as needed. There's no guesswork about which capacitor will do what I need and there's no soldering station required.
  6. closedmri
    Chicago
    I’m looking to minimize what I need between guitar and amp to get the sounds I want. I think using an EQ in this instance would not have the same effect as tailoring the sound before it leaves the guitar with passive electronics.
    Just to make sure I’m understanding correctly, the change in capacitor value affects the total amount of bass that can be rolled off as opposed to at what frequency the roll off occurs, right?
  7. SuprHtr
    Rocket City
    Actually, it affects the frequency. The capacitor is a first order high pass filter in this configuration, with a theoretical maximum 6dB decrease in output when potentiometer resistance goes to infinity . When the pot is zeroed, there should be little or no cut.
    closedmri likes this.
  8. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    This is how G&L does it.
  9. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    If you haven't already, you may want to check out the Fender TBX pot to see what it could do for you. It is a stacked pot which does something similar to what you described. I ordered one the other day to try on one of my Teles.
  10. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Generic stacked/concentric pot with concentric knob set gives you both a regular tone and bass roll off.
    Open this video in it's own tab, follow the breadcrumbs in the video notes "show more" to link to the article and wiring diagram. It's easier than the G&L which takes ordering some special parts and I found this one worked much better.
  11. closedmri
    Chicago
    Thanks guys! That Joe Gore video was part of the inspiration for wanting to give this a shot. The TBX knob does sound like a good idea, more versatility. For now I think I’m going to try out stock pots since I already have em and won’t need to wait for another part to ship. My guitar is just waiting for me to finish it!
  12. SuprHtr
    Rocket City
    Or:
    I plan to use this wiring arrangement when I build with the three Z-coils I got on close-out last year.
    Peegoo likes this.
  13. adamsappel
    adamsappel Tele-Holic Silver Supporter
    Maryland
    I really like the TBX tone pot I have on a Strat. I also like to set the standard tone knob on my guitars at around 5 and make amp adjustments from there.
  14. beanluc
    beanluc TDPRI Member
    California Bay Area
    Is this 6db per octave, or is it really only 6db and no more than that because of the small resistance of the pot?
  15. SuprHtr
    Rocket City
    Sorry, per octave, yes.
  16. Finastbeans
    Finastbeans Tele-Meister
    Maryland (DC area)
    Recently did this on my dual humbucker Harmony Guitar. I would recommend experimenting with cap values using alligator clips to get the right level of high pass. I also ended up with a resistor in the circuit to maximize the usable travel of the potentiometer, otherwise most of the cut happens in the first few increments of turn. Here is the wiring diagram...
    kaludjerko likes this.
  17. beanluc
    California Bay Area
    Hypothetical. Does anyone know what difference it would make if the treble control were wired before vs. after the bass control?
