Bass Amp Making Chirping Sound… Rumble
  • Thread starter Tele-beeb
PhredE
Suburban PDX, OR
Like when I dig in, it sounds like I shocked a cricket.
Ideas?
Oh… Rumble 500 combo. Well used.
Playing guitar or bass ?
Edit: My instinctive answer right away is a speaker issue; but it would take some more investigating to isolate it as the cause. Have you tried to output from same amp to different speaker?
Tele-beeb
The Bluegrass
Thanks… bass.
Happened last weekend and I turned down and ignored it. I run two matching 500’s and just forgot to check it.
Last night same chirping. Now it has my attention. Will get it out of the trailer in a bit. Thanks, I’ll check those.
Tele-beeb
The Bluegrass
Well… I just did a quick test at gig volume without my wireless, preamp board and effects. No chirp. I am considering bypassing the front end and just go into the return with my Geddy preamp.
CoolBlueGlow
Arkansas
Recently had a Rumble with this problem. I replaced the common electrolytics. It went away. Not very hard to fix. Mine was in the PSU, but same chirping as you describe.
So, just swap out the obvious electrolytics with fresh cookies. Dollar to a dime it'll go away.
corliss1
Lansing, MI
Always isolate first. Remove as much from the equation as possible - bass -> cable -> amp. Much easier to troubleshoot when there are fewer variables.
Dostradamas
Off the shoulder of Orion
On or off?
This would be my first check
