robbiej1959
Every guitar I've ever owned or played, if you tune an open string, then fret a note on the same string, it will be sharp. If I press very very lightly this effect is reduced almost to nothing, but I don't think most players have that light a touch. So its finger pressure is driving the fretted note sharp.
So my question is why don't guitar makers change the fret location to flatten the fretted note slightly to compensate for an 'average' finger pressure? Or maybe 'sharpen' the nut position although I'm not sure that gives the same result.
I usually tune the guitar so the open strings are slightly flat and the fretted notes slightly sharp. This is the best solution I have found to make the guitar sound in-tune.
Most discussions around intonation center around adjusting the bridge to get the 12th fret and harmonic in-tune. Haven't heard anything on this exact topic although its probably out there somewhere.
I'm anticipating responses saying properly set-up guitars don't have this problem, but I am 63 years old and have been playing for about 55 years. Lots of different guitars. Electrics. Acoustics. Cheap. Expensive. Old. New. I find it hard to believe I've never played one properly set-up.
Thanks for your attention all!
