Barrel switch tip in the way
Chicken Curry
Play more from the wrist and less from the arm. If you anchor, anchor on the high E. My hand barely goes outside of the string spacing.
Interesting. This post made me analyse how I pick. I don't really play from the arm, more from my wrist. I could improve and clean that up a bit. I don't anchor anywhere, my hand just floats (I left hand mute when I play off of the bass strings), except when I palm mute then my palm rests bridge plate edge (52AV).
The reason I keep hitting the switch is because my fingers stick out, particularly my ring finger. I think it's because of musscle tension, trying to concentrate on something makes me extend my fingers, seem more natural as well.
naneek
PNW
sure. it's currently missing its high e string, which is a little embarrassing, but here you go.
modified "top hat" switch tip and reversed control plate on my old squier affinity "surfcaster" / "thrashcaster" beater guitar
just look at that control plate, this guitar has been played a lot
the switch tip got painted white along the way, which made it a little more rounded and made the edges less defined.
the finish has worn over time, but I still like the way it looks.
about 15 years ago I painted the guitar in a dark green duplicolor auto paint and matte clearcoat.
it sure has that punk rock homemade look but I'm pretty happy with it.
fender4life
los angeles
If you don't wanna reverse the control plate and flip the switch 180 degrees...
I learned a cool trick from Danny Gatton (Peace be Upon Him): bend the switch lever downward to move the knob downward. It's not much of a change, but it makes a world of difference. Make sure to bend it at a point that allows it to smoothly traverse all positions.
You can see it here (click on the pic to embiggen it):
I have seen that and tought about doing it and maybe now i will. But i wonder....why bend it down rather than up? Obviously i can't ask Danny but have you tried bending it up towards the strings rather then towards the floor? Just seems like it would be closer and better that way. Or maybe it would get in the way of the volume too much?
Peegoo
Beast of Bourbon
The problem here in the OP is the switch was getting in the way. Bending it upward would make the problem worse :oops:
fender4life
los angeles
Ok, i always thought it was to eliminate the tip being close to the volume so it was easier to move from the bridge position to the middle or neck. For me i think bending it up would be the way to go, as the switch never gets in my way. Only issue i have is quickly switching from the bridge position. Not that its really an issue but bending it would make it more natural like going from neck to middle or bridge.
That Cal Webway
Minot
Without the tip my Tele is more aerodynamic in a sense. My thumb flew off right into the kitchen just like that!!
Peegoo
Beast of Bourbon
Or put a blob of hot snot in a .22 short case and press it on the lever.
If you ever need to remove it, warm the lever with a soldering stick and it slides right off.
Killing Floor
Austin, TX
A true professional! Label side out. And the cig to pull the lower strings slightly sharp to account for the low tension from the slide angle.
PCollen
Space Coast, FL
I play mainly in the neck position, My 52 AV has a barrel switch tip, big and fat, in the neck position my fingers keep bumping into it. Does anyone else find this annoying? I thought I'd get used to it but I didn't. Thoughts, advice?
I know, it's not the biggest problem, I have it off on my AO, it gives me more room for my fingers.
I change that switch tip out for a Stratocaster switch tip.....
