Some time ago I've made this 28-1/2" scale baritone neck using Stewmac's fret template, however I abandoned it at the time for various reasons. A few days ago I decided to fix most of the problems it had, installed frets, refinished it and now I want to pair it with a cheap strat body I bought off eBay some time ago. The problem is that when I dry-fit it and measure, the bridge location should be about 3/8" closer to the neck. I understand the reason for that, and I know that I need to shorten the neck a bit, which will bring the 12th fret closer to the bridge and ultimately in the right position, so I can properly intonate the guitar.
How do I shorten the neck enough, while keeping the neck heel radius intact? Any ideas are greatly appreciated?
