Bare back
Discussion in 'Finely Finished' started by Dick Hutchings, Oct 4, 2019.
  1. Dick Hutchings
    Dick Hutchings TDPRI Member
    RI
    I want to remove finish from just the back of the neck and apply tung oil to it. How would I go about blending it in to the lacquer finish I think at the head and heel? This is a 70's Strat with maple fretboard.
  2. ale.istotle
    ale.istotle Tele-Meister
    Pennsylvania
    What's the end goal? Why do you want lacquer off and tung oil on? If you want more of a satin or less glossy finish the consensus seems to be white scotchbrite pads. Avoid steel wool because you'll get steel on the pickups. You could go more aggressive to get down to or near natural wood. Maybe no added finish would be needed.
    If you decide to add finish I'll defer to others how to blend. I'd be worried about blending as you are.
    8barlouie likes this.
  3. 8barlouie
    8barlouie Friend of Leo's
    Seekonk, MA
    I’m pretty sure the finish on a 70s Fender neck is poly, not lacquer. You would be well-served to just scuff it up with Scotchbrite as already suggested.
    OldDude2 likes this.
  4. Dick Hutchings
    RI
    I'm not concerned with the look, just how it feels. I want slippery. I imagine the scotchbrite will only last a little while. I want permanent slippage!
  5. Davecam48
    Queensland Australia
    A long time ago I saw something about a company that etched a fine criss-cross pattern on the back of a neck by burning it into the wood slightly with a laser CNC. Apparently it worked on the principal of air trapped in the laser cuts by the player's hand..........or something like that.
    DC
  6. Davecam48
    tubedood likes this.
  7. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    Dean Zelinsky Private label has it as an option, and stock on some guitars. Interesting business concept, 1 showroom, rest is online only. They have an excellent return policy. The guitars are made in India and set up here. Their necks are often lacquered high gloss, but the laser etch supposedly decreases hand contact area, and hence decreases friction. The necks are definitely faster than high gloss, but is it just a gimmick, and no better than satin or bare? I don't think so.
    Check out Dean discussing the idea here:
  8. Dismalhead
    Sacramento, California
    Yeah, I'm not sure Tung Oil is a good idea for a smooth finish-free feel. I did a body in Tung Oil last year and it's still a little tacky 12 months later. Not what I'd want on a neck at all.
    I've sanded the backs of the necks on about half my guitars. Just use fine grit paper (400+) and then spray poly clear - just one or two light coats and then lightly sand again until smooth.
  9. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Not sure about pure tung oil but tung oil finish does make for a nice feeling neck. I finish the back of one last year and it turned out great. I lacquered everything except the back of the neck and then applied the tung oil finish to the back. My neck was dyed vintage amber first and then the clear lacquered and tung oil finish was applied over it.
  10. corliss1
    corliss1 Friend of Leo's
    Lansing, MI
    Is the neck otherwise in good shape? If so, I'd just order a new neck with what you want. Then you'll have the original neck in unmolested condition should you ever want to sell the guitar.
    2 Headed Goat likes this.
  11. tubedood
    tubedood Tele-Meister
    Orlando
    I am very curious about the Dean Z Neck.
    Seems so crazy... It just might work? I dig the Dean models from the 80's I am confident this Z Neck has its merits!
