Barbrainy Momento: A Re-fin Project Thing
Discussion in 'Tele Home Depot' started by Captain Nutslot, Jul 24, 2016.
  1. Jupiter
    Osaka, Japan
    ganbatte!
    I have TWO guitars that aren't wired up right; at a certain point, I just stuck a spork in it and called 'em done. Of course, that is not an option on a brainy momento...
  2. Captain Nutslot
    Captain Nutslot Friend of Leo's Silver Supporter
    Rochester, NY
    Right! I don't wanna let Rob down either. I'm going out to play around in the world, I'll try to find a spdt switch to try later today... Oh ya. Unplug the soldering iron...
  3. Jupiter
    Osaka, Japan
    amazon! I put the link in the other thread.
    Captain Nutslot likes this.
  4. Captain Nutslot
    Rochester, NY
    Flick my nut on the price!
  5. Jupiter
    Osaka, Japan
    I...is that good or bad?:confused:
  6. Captain Nutslot
    Rochester, NY
    Good. I got flicked on the one I have now.
    Jupiter likes this.
  7. R. Stratenstein
    Loganville, Ga.
    You could just wire up a patch panel and make up about a dozen jumpers. Makes it very easy to visualize the circuit that way...
    EDIT: it just occurred to me that about now, while futzing with the wiring, Brainy would have noticed something he didn't like about the finish, and next post, the guitar would be sanded bare, ready for another try. Not suggesting this for you, of course.
  8. Captain Nutslot
    Rochester, NY
    Ha!
    I kinda wanna get the woodworking done on another build before winter sucker punches us!
  9. R. Stratenstein
    Loganville, Ga.
    U got bad winters there. U needa shop. Who needs a living room? Capisce?
  10. Captain Nutslot
    Rochester, NY
    I would loooove a shop. On wheels!
  11. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    Regular or double wide?
  12. Captain Nutslot
    Rochester, NY
    Triple long
  13. jimdkc
    jimdkc Friend of Leo's Silver Supporter
    Independence, MO
    That switch arrangement gives you either coil alone, or both coils in series... but not both coils in parallel.
    In the center OFF position, neither of the outside terminals are connected to the center common terminal.
  14. Captain Nutslot
    Rochester, NY
    Do you know if the middle position being labeled as 'off' vs. 'on' has any bearing on what I am trying to accomplish here?
    Thanks man but I'm Currently not interested in parallel.
  15. Barncaster
    Northern California
    Hey CJ,
    The diagram Jim showed before put the coils in parallel for humbucking mode. This is like normal Tele switching but a 4 way allows for series as well.
    Also, there is a famous guy in some of the other forums called Deaf Eddie. He is a wiring guru. I'm going to take a look now.
    Rob
  16. jimdkc
    Independence, MO
    Yes, absolutely...
    ON-OFF-ON means that the middle position has the common terminal (center) completely disconnected from the other two terminals.
    ON-ON-ON means that the common terminals are connected when in the center position. If you look back at my first diagram, you can see that as you move the toggle from top to bottom, it goes from top 2 terminals connected to common... to one-top-and-one-bottom terminal connected to common... to bottom 2 terminals connected to common.
  17. R. Stratenstein
    Loganville, Ga.
    Make yer life easier, get a SPDT on-off-on switch and wire it like the diagram you posted. Save the Unicorn switch for something later.
    EDIT-posted the wrong switch designation. Changed it--it's right now.
  18. Captain Nutslot
    Rochester, NY
    Yes
  19. Captain Nutslot
    Rochester, NY
    Thank you sir... Gold info!
  20. Captain Nutslot
    Rochester, NY
    Ok, I went out and found a radio shack. Bought these guys... Let's see what happens with that spdt with the mike and Ike switch tips
