Barber Pedal Owners Club
Discussion in 'Pedal/Effects Owners Clubs' started by Agitator, Mar 25, 2013.
  1. GeorgiaHonk
    GeorgiaHonk Tele-Holic
    Auburn, Georgia
    I really like Dave's ear for tone and the way he voices his pedals. I used to own an original Burn Unit that sounded amazing into a SF Pro Reverb. Now I own an LTD that sounds amazing into my Lil Dawg. Barber effects are definitely bang-for-the-buck superstars, and I am all about that with my pedals.
  2. Twangstrom
    Twangstrom TDPRI Member
    Helsinki
    Barbers have been in my signal chain for over 8 years now. Tonepress, Launch Pad and an old handwritten Direct Drive. I tried to replace the LP for another clean boost but after 2 minutes I realised I cant rid of the Launch Pad. Its my favorite pedal of all time.
    I am really wanting to try the Compact Direct Drive and the Small Fry.
  3. craig.collas
    craig.collas NEW MEMBER!
    penang
    Started out with the tone pump ++
    Then the half gainer ++
    And small fry
    I think I am hooked! That is my sound with an. Analog man delay
    The small fry is the lead tone and works so well playing with the volume on the guitar
  4. blotchard
    blotchard Tele-Meister
    Sudbury
    I have a Gain Changer and a Direct Drive incoming!
  5. twangjeff
    twangjeff Tele-Afflicted
    Houston, TX
    Didn't realize that there was a Barber thread. I am a long time Direct Drive user. My favorite overdrive by a long shot!!!
  6. semi-hollowbody
    semi-hollowbody TDPRI Member
    Metro Detroit, MI
    Im in!
    I own:
    ltd sr
    tone pump
    1/2 gainer
    direct drive
    small fry
    trifecta
    tone press
    dirty bomb
    launch pad
    barbq
    so yeah..barbers aint too shabby lol
  7. Rolfi
    Rolfi NEW MEMBER!
    San Francisco
    I'm a new member and apparently obsessive-compulsive. I started with LTD SR and now own: LTDSR, LTD, UNLTD (dual), 1/2 gainer, B-custom (LTD/ b-custom SS), Direct Drive, Direct Drive LG, Small Fry, B-custom Cool, just ordered the tone pump EQ...
    the pedals have a vast range of sound to be dialed in via the ext. & int. knobs. So, if youre too lazy to adjust them for different sounds, just by them all and have each adjusted a bit differently.:)
    Rolf
  8. 73Fender
    73Fender Friend of Leo's
    Jersey Shore
    I'm kind of new to the pedal world but the Tone Press got me started and if I could only keep one pedal that would be it. The quality is apparent. I need to check out more Barber stuff. I like a non fuzzy od, subtle. I'll re read this thread again, there were a few mentioned. I've been experimenting lately with other pedals (OCD, Timmy, Jacques Overtube) and they may get moved on.
  9. kelnet
    kelnet Telefied Ad Free Member
    Port Moody, BC
    The lead guitarist in my band was selling his Direct Drive, so I bought it from him for $75.
    He constantly lets me know that he'd like to buy it back. But it's mine now, and I'm never letting it go.
    This thing sounds great. When I need to go loud and dirty, it maintains real clarity and precision, with great bite and growl.
  10. nathanteal
    nathanteal Tele-Holic
    Rochester, NY
    Just acquired a Gain Changer. I've been eyeing these since they first came out but for whatever reason I got sidetracked by the supposed "best selling" overdrive on the market, which I wound up hating after about a month. The Gain Changer is my new standard. It is easy to get just right because it's all around just right. I spent maybe 5 minutes on it and located my two favorite spots and proceeded to tweak my Jetter Gold Standard for 10, trying to get both sides set to mimic my ideals on the GC. Now...my setup sounds awesome. I use the GC as a boost with a light overdrive to it and it just sweetens everything up.
  11. simonsp
    simonsp Friend of Leo's
    England
    I've just given into my gas and scored the Barber Gain Changer. I've only had it a very short while so I won't gush too much but Wow!
    Anyway, I have a question. It says that it can be powered by 9 - 18 vDC. Is there any advantage in running it at a higher input? I had a look on their website but can't find any info there about this. I'm currently powering it with a 12vDC supply (1st to hand) and it's sounding wonderful but what gives with this variable power thing? Any info or advice gratefully received.
    A picture.
  12. nathanteal
    Rochester, NY
    My guess is that it's mostly a convenience thing. If you have only so many 9v slots on your power supply and some 12 or 18v slots to spare, you can run the mandatory 9v pedals on 9 and put the variables wherever.
    There are those who purport that running od pedals on 18v supplies you with more headroom, but there are also those who say that whatever difference it makes, if any, is negligible. I have not tried comparing the two so I cannot corroborate anything either way.
  13. simonsp
    England
    Thanks for the info. Headroom's not an issue at present for me. Running at 12 vDC seems fine. It's a very tactile pedal isn't it, it responds to the slightest pick or touch. I know I'm really going to go for this one.
  14. simonsp
    England
    Just got the small form version of the Tone Press. Having put a bar on all pedal stuff I couldn't resist it. I flipped a couple of pedals to pay for it including my Boss CS-1 which has been a favourite of mine for quite a while. I decided that I wanted something with more options and the possibility of a more gentle compression regime. The Tone Press was the front runner for me due to its blend capability and the switch that boosts the top end.
    It's a great compressor, I haven't played around with the settings too much yet, I just dialled in a sweet spot and played for an hour straight. So glad I discovered Barber's pedals, they make quality gear. All thanks to TDPRI, thanks guys!
  15. Dunzie
    Dunzie Tele-Holic
    Southwestern Ontario, CAN
    I added the Gain Changer this past week after being impressed with plenty of videos on it over the past year or so. And I'm not disappointed, it's definitely a great stackable low-to-mid gain drive!
  16. simonsp
    England
    Spent more time with the Tone Press (the small one with multi switches). What a superb compressor it is. I especially like the subtlety switch for attack set to fast. It opens up a whole world of palm-muted sounds and harmonics, brilliant for r n b and funkish tones. Love this little box. :cool:
  17. WayneT3
    WayneT3 TDPRI Member
    Houston, TX
    Amen, friend; I'm a Tone Press disciple myself - mine stays on most of the time I'm playing....
  18. Carvalho Diablo
    Carvalho Diablo Tele-Meister
    TLW GF
    My Burn Unit is a a great sounding pedal, two levels of gain, rhythm and lead in a box.
    Very, very "valvey".
    surfspeck likes this.
  19. Freethenoise
    Freethenoise Tele-Holic
    Love the crap out of my Gain Changer, use it everyday:
    Sounds so good with any Fender voiced amp.
  20. jmclaren
    jmclaren Tele-Holic
    Southern California
    I've owned the LTD, Tone Press and Direct Drive over the years. I currently have a Compact Direct Drive on my board. I've had at least one Barber pedal on my board for more than 10 years or so.
