SerpentRuss
I am finishing up a current build that is a 5-watt SE head and I thought about adding a balanced output jack like I saw on another's schematic. It seems like a bit of a shortcut, no dedicated transformer, but I wondered if anyone has done something like this. As a side note, I am including a switched load resistor so I can run the head without a cabinet and I plan on putting in the headphone jack like the attached drawing shows. This I've done before.
I do have a couple of nice direct boxes, so I could always feed a balanced output using the headphone jack and one of them, but I thought this might be interesting to try.
The output is created by using a stereo jack and one dropping resistor from the speaker positive to the tip, another equal dropping resistor from the speaker negative for the ring. The sleeve is left unconnected, so the ground reference is lifted to the next device.
What do you think of this method, does it have any merit?
