baja vs road worn 50s neck profile thoughts?
Discussion in 'Telecaster Discussion Forum' started by Rumblur, Sep 16, 2019.
  1. Rumblur
    Rumblur Tele-Meister
    Upstate, SC
    I've got a road worn Tele, the neck is huge, full thickness all the way. That I can deal with, even if it is a bit bigger than I would like. The 7.25" radius and jumbo frets are not my thing. that radius and regular frets = fine. 9-12" radius and big frets = fine.
    So I'm thinking about a Baja neck, but I can't find a single Baja Tele in my area to try out... so can any of you Tele-lovers compare these 2 models for me to give me an idea of how the Baja neck differs from the Road Worn 50s?
  2. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    I cant help with comparison, I only have a Baja (which has a great neck) but if you ever want to sell on the road worn tele neck im very interested! :)
    SnidelyWhiplash and Rumblur like this.
  3. declanaungier
    declanaungier TDPRI Member
    ireland
    I’ve had three Bajas and they all have had different necks so it’s really difficult to surmise.
    Fretting out and Rumblur like this.
  4. Rumblur
    Upstate, SC
    wow, 3 and all different? I figured since the advent of the CNC machine everything was identical more or less. I'm really hoping for a comparison by someone that's handled both of these models.
  5. Crawldaddy
    Crawldaddy Tele-Holic
    Singapore
    I've handled 2 Bajas in recent years and they were pretty consistent; about 0.9" at the nut. However, I never found the neck to be a soft V. Felt more like a very rounded C shape, almost as deep as the Nocaster deep U, but with slightly less shoulder.
    It is certainly larger than the road worn tele neck that has a neck profile probably similar to the Suhr C shape.
  6. BrandonIke
    BrandonIke Tele-Meister
    South Jersey
    I have both. Baja neck is definitely bigger. Road worn is a pretty normal mid size c shape.
  7. declanaungier
    ireland
    Just to clarify. All the necks had the same profile but the difference in thickness was considerable. Also the most recently built one had almost a Baseball Bat type neck. The first one was a Desert Sand model and it had the thinnest neck.
  8. jim777
    jim777 Tele-Meister
    South New Jersey
    They need to start making the Bajas in different colors, I need a reason to buy more of them :)
  9. RadioFM74
    RadioFM74 Tele-Afflicted
    Italy and Switzerland
    They jus did: see Vintera modified line ;)
  10. jim777
    jim777 Tele-Meister
    South New Jersey
    Do those (the maple boarded ones) really have the Baja neck on them? If so then yeah, I'm definitely up for one of those! :)
  11. Aaron1061
    Aaron1061 Tele-Holic
    Troy, AL
    yup! the vintera modded 50's are full spec in line with a baja. except satin back of neck, different colors, and the tuners are a higher ratio.
  12. jim777
    jim777 Tele-Meister
    South New Jersey
    NICE!! :) I love the Bajas, they are damned near perfect. Looking at Fender though, it looks like the Baja has the 9.5" radius and the Vintera has a 7.5" radius neck.
    EDIT: Ok, so the Baja appears to be gone, the Vintera has the 7,5" radius, and the Vintera Modified has the 9.5" neck. lol
  13. RadioFM74
    Right. The Vintera modified is the new Baja. The Vinteras are the new “Classic” (with revised neck shapes and pickups, but still full vintage spec).
  14. jim777
    jim777 Tele-Meister
    South New Jersey
    There's a pretty cheap Baja neck on reverb right now, looks like it needs a new nut though. Not mine, just pointing it out.
    https://reverb.com/item/27892326-fender-baja-telecaster-neck-and-tuners
  15. TeleTown
    TeleTown Friend of Leo's
    Twangers Medows USA
    Heck, I wish my road worn came with a fat neck. Mine is a tooth pick.
    Fretting out likes this.
  16. Rumblur
    Upstate, SC
    strange.... I was under the impression the baja was SMALLER than the RW50! My RW50 is the thickest neck I've ever seen on a Tele, and there's no taper. At the nut and the cowboy chords it's fine, but once I get up the neck a little it isn't very comfortable.
    Thanks for the info on the Vintera, I'll keep an eye out.
  17. felis
    felis Tele-Afflicted
    Antwerp/Belgium
    That's my experience also!
    And also this ↑ ↑ ↑
    e.g. what I call a 'V' shaped neck ↓ ↓ ↓
    And for the purists :D;), another remarkable difference!
    Pechorin and declanaungier like this.
  18. raysachs
    raysachs Friend of Leo's Silver Supporter
    Near Philly
    That’s my experience too. The Bajas I’ve played and one I’ve owned (just in recent years, so probably nothing earlier than about 2015) have all been considerably fatter / thicker than the roadworns I’ve played. To me, the road worn has been my “Goldilocks” neck, definitely not skinny but not fat either, just kind of disappears in my hand. I like the Baja necks, but I was always aware I was playing a fat neck. And I DO like the 7.25” radius and narrow / tall frets on the road worn, a LOT!
    -Ray
    BrandonIke and tele12 like this.
  19. Fretting out
    Fretting out Tele-Holic
    Land of Mary
    This is interesting I had no idea the tokai teles had v necks
    And for what it’s worth I find you have to be looking for a v to feel it on most bajas if it wasn’t known in the specs as a v most people probably wouldn’t call it a v shape even a soft v
    To me my baja neck actually feels closer to a early to late 70’s U shape
    felis and raysachs like this.
  20. Pechorin
    Pechorin TDPRI Member
    SW of England
    Interesting indeed, and it brings back the memory of a Breezysound I owned in the 1980s - yeah, definitely a 'V'.
    felis likes this.
