rschiller
I am having an odd humm issue when I plug into two amplifiers simultaneously. I need a bit more headroom for a job. Both amplifiers are 1958 Fender 5E3 Deluxes. Both have been gone through and filter caps replaced. The amp I primarily use has had the Coupling Caps replaced w/ Mallory 150s and the other amp has the original Astrons which are slightly leaky. I do not think this the issue. Individually the primary amp is dead quiet and about as quiet as a tube amp can get. The other amp has slightly more background hum (leaky Astrons?) but is certainly in the range of properly working tube ampliifers.
So I daisy chained by plugging into INST 1 input and then a jumper cord from INST 2 to the other amp INST 1. A Loud hum which immediately goes away by turning one of the amps off. As this was not my ideal solution, given the amp with both Inst 1 & 2 plugged into would have reduced input gain, I made a splitter box. The box is a metal case though to be sure I used a shielded cable from the input jack to one of the output jacks. Same hum problem. Both amps are plugged into the same wall socket and the socket has been tested with an electricians circuit tester and is working properly. Both amps have the AC (aka death cap) removed and properly installed grounded 3 wire AC cord. Ground switches are disconnected as cap is removed.
Why the hum?
Why the hum?
