theprofessor
I started building amps for fun a few years back with a 5f2a, yielding a thread of epic proportions for such a small amp. I had a lot of questions, and folks were kind enough to pitch in. I hope that, despite its absurd length, that thread has been helpful to others. I then went to a 5e3 tweed Deluxe, a 6g2 brown Tolex Princeton, a 5f4 tweed Super, a few Princeton Reverbs, and then a Vibrolux Reverb.
You know how sometimes you end up with a bunch of vintage power tubes singles and leftover capacitors, resistors, and hardware from previous amp builds and some scavenged odds and ends like Cinch sockets and tag strips from old power amps that a neighbor gave you? And then you decide that you pretty much _have to_ build a single-ended amp so that those things just "sit in a box"? Well that's what I thought!
Yes, a 5f1 is basic, but I am glad that others directed me to build a 5f2a first. There's just more room in a tweed Princeton chassis, and despite being a simple circuit, there are still a lot of decisions to be made and maneuvering to be done in a very small space. Make sure you have a good pair of tweezers handy! A Champ is great, so long as you make all the decisions ahead of time...
With the shuddering of ClassicTone, I decided to use Hammond transformers (PT: 290AX, employing the 275-0-275 secondary; OT: 1760CP). I never use the "Lo" input on a Fender amp, so I decided to put the cathode bypass cap on a switch, just for grins. I used @robrob 's layout for input and switch on his 5F1M Champ Micro as a guide. Beside that, there is his great split-bus layout for a more traditional 5f1. And then I used @King Fan 's thread on an optimized single-bus 5f1 as further inspiration for some "upgrades," such as an "elevated" heater center tap at the cathode (pin 8) of the 6V6GT power tube, a separate power switch instead of the switch-on-the-back-of-the-pot-jobber, the fuse moved to the bottom of the chassis, and so forth. I decided not to use a screen grid stopper on the power tube (at least yet) and to add the backup rectifier diodes as well. I got a stainless chassis from Zach Hunter and Carl in Little Rock, and... voila! - a Champ.
If you like, please feel free to give this a gander and comment on anything wrong or just dumb. Or anything right, too!
