B-Blender problem
Discussion in 'B-Bender Forum' started by Boreas, Dec 25, 2019.
Tags:
  1. Boreas
    Boreas Tele-Meister
    Port Kent, NY
    Actually, the kit comes with a snap-on piece of Delrin that snaps onto the pivot bar to address that situation. So it isn't metal-on-metal. Plus it has the ability to spin on the bar as well.
  2. AndyPanda
    AndyPanda Tele-Holic
    Bay Area, California
    Are the bridge saddles roller saddles? If not, you can polish the string groove in the saddle (not the nut - the saddle at the bridge). I'd look at that saddle slot with a magnifier and perhaps shape the back of the string groove it so the string has the smoothest path. And try some lube in that B saddle groove.
    Boreas likes this.
  3. Boreas
    Boreas Tele-Meister
    Port Kent, NY
    This one has roller saddles. They seem to work the best.
  4. Pineears
    Pineears Tele-Afflicted
    DIY soldering not required.
    Boreas likes this.
  5. Boreas
    Boreas Tele-Meister
    Port Kent, NY
    Thanks! I found out about these the other day. I have ordered a few sets.
  6. Boreas
    Boreas Tele-Meister
    Port Kent, NY
    D'Addario sent me two replacement soldered B strings and a set of soldered strings. Very nice of them. They gave no explanation, so hopefully the soldered connections will take care of the problem. We'll see...
  7. Boreas
    Boreas Tele-Meister
    Port Kent, NY
    All - thanks for your help. I believe I have the problem sorted. It appears it was NOT a string problem but a design/manufacturing issue with the B-Blender. Yes, the strings were unwinding, but only after being cut by the mounting hole. I should have examined the damaged string more carefully. The break was down in the winding. As you can see from the pix, an upbend on the whammy arm would cause contact with the string windings. So I will break out the Dremel and widen and smooth the hole for the string so the ball sits deeper. That will bring the exiting string closer to the center of the hole, avoiding contact. I will also enlarge the exit while I have it apart. I will also send the info to Jim Alday.
