B-Bender on a Les Paul Jr.
Discussion in 'B-Bender Forum' started by bendercaster, Oct 22, 2020.
  1. bendercaster
    bendercaster Tele-Afflicted
    Sacramento
    Do any of you have experience with playing, installing, or having a b-bender installed in a Les Paul Jr.?
    I have a great sounding Les Paul Jr. that I would love to have equiped with a bender. It has a brass adjustable zero fret nut and the traditional wrap around bridge. I've seen Juniors with a bender before, but I wonder if anyone has direct experience with one--who installed it, did it stay in tune, did the wrap around bridge rock too much, etc.? It's a little heavy too--probably around 8lbs--is that going to pull it out of tune too easily?
    Thanks guys.
  2. brookdalebill
    Austin, Tx
    Frank Reckard, with Emmylou’s Hot Band famously used a “Sully steel” on his late 50’s double cut Junior, with great results.
    I have put Hipshots on a couple of LP Specials over the years.
    They worked well, too.
    JRapp and bendercaster like this.
  3. Fearnot
    Fearnot Poster Extraordinaire
    Decatur, GA
    Gibson made one for awhile.
    bendercaster and brookdalebill like this.
  4. bendercaster
    Sacramento
    I know. I'm kicking my self for not buying one a number of years ago when they were blowing them out for under $1000. They are harder to find and more than twice that price now.
  5. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    Well the ( Music City Jr) Les Paul jr with the Glaser, were made for two years, they made somewhere between 500 and 700 of them , 2012 and 2013 if I recall, They sold for $1299. I don't recall them ever being blown out for under a grand, ( maybe) they didn't last that long to begin with. They were very difficult to find even when in production. I suspect Gibson underpriced these guitars big time as they were trying to compete with the Fender Parsons Green. A USA Les Paul jr and a Glaser installed Bender for $1299. wow.
    These are nice guitars, typical Gibson build , 12" radius with very tall frets. The Glaser system is strap actuated from the body just like the Fender PG rather than on the neck plate. It can also be converted G to B or B to G. Grover tuners ,Gibson P-90's and a hard case, whats not to love !
    If there is a negative its that the neck is unfinished and gets dirty rather quickly. The fretboard can turn black from finger dirt and natural oils, but there is a simple cure. Remove the strings of course, clean the fretboard, fine sand with 600/1000 grit and lay 3 very thin coats of semi gloss clear on the fretboard. Allow each coat to dry for a full day. Lightly sand again with 600/1000 grit and repeat. ( 3 times)
    The frets are in the .050 tall +/- category, compared to a Tele with .045 or shorter. I had mine dressed down to .043. NOW its in the same camp as my Telecasters and lighter gauge strings are not an issue, especially a .042 / 6th string in the 9 's set. I do however have mine strung with 10's.
    IF you can find one, grab it, apparently the going prices are above $1500 to over 2 grand. Its not like there are thousands of them around, more like +/- 700 in total. I think the appropriate legitimate price is right around +/- $1600 in top shape.
    Nice guitars but they are not Telecasters and don't expect them to be !
    bendercaster likes this.
  6. bendercaster
    Sacramento
    They were very reasonably priced when they came out. But I do recall seeing one or two of them on Reverb in the $900 - $1000 range at some point. Oh well. There weren't any listed on Reverb when I last checked, but their price chart shows them selling for over $2k recently.
    The Fender B-bender has followed a similar pattern. My GC had a new one for sale for $1000 just hanging on the wall forever and I used to occasionally see used ones locally in the $800 range. Now I see them on Reverb for $2000 +.
    T Prior likes this.
