shaynejacopian
Hi everyone,
I’m here to see if anyone smarter than me can confirm that this pickup wiring concept will work before I take my Tele to a professional tech.
I’m basically going for a Nashville Tele with a Seymour Duncan Vintage Stack in the bridge, and true single coil Strat pickups for the middle and neck.
Using the standard Tele 1 vol/1 tone configuration, a standard 5-way switch wired Strat-style, and a push pull pot, I want it to do both of these things (separately):
- Split the Vintage Stack in position 2 for hum cancelling with a RWRP middle pickup.
- Use a push/pull to add the bridge pickup (in the normal stack mode) to only positions 4 and 5.
Based on my limited knowledge, I know that both of these things are doable individually, but are they both doable with a standard 5 way and a push pull pot?
