JohnnyKRed
Anyone have experience with a Dr Z or similar attenuator to push a deluxe? Thinking to get my JBL E120 speaker to push harder (more juice) than having my amp on 2.
I think I follow, the attenuator would limit the wattage hitting the speaker itself so would only affect the amp.An attenuator will reduce, not increase, the signal hitting your speaker. If you want to crank the amp higher, thus a dirtier signal hitting your speaker, at lower volumes than the amp without the attenuator, an attenuator will do that.
Cool thanks! It’s a 65 reissue. My assumption here is that the E120 sounds best when pushed with something like 100 or so watts.What kind of "Deluxe?" There are many types.
If you're looking for cone breakup, that only comes with twisting the volume knob to loud without an attenuator. It's a waste of time, as that JBL isn't going to have cone breakup anyway.
An attenuator reduces the signal from the amp before it gets to the speaker. If you want a fatter tone from your DR, an attenuator will get you there. I have a '74 DR with a Weber Signature 12A-S speaker and the whole rig fattens up by 4 on the volume. I use a Weber MiniMASS attenuator to rein in the volume, 'cause 4 is loud in the house.
I didn’t know you could buy an individual attenuator for amp use. I thought they only came built into amps. Can someone post some links to one. I would love to try one on my Twin Reverb.
Are you referring to the output tubes pushing out 100 watts or tbe speakers actually receiving 100 watts? An attenuator can allow the former to happen (if you could actually wring 100 watts out of a Deluxe) at more reasonable sound levels while preventing the latter from happening (from the speakers seeing 100 watts to act upon).Cool thanks! It’s a 65 reissue. My assumption here is that the E120 sounds best when pushed with something like 100 or so watts.
