skipjackrc4
I've never played a Jaguar, but I like the look of them. So it's time to build one!
I couldn't find any decent ash locally due to the emerald ash bore (probably), so I had to order a blank from Stew Mac. It's decent quality wood and feels pretty light, but there's some pretty bad snipe on both ends that limits the thickness to less than 1.75". I'm not too concerned with losing a bit of thickness, but I'm annoyed that I have to deal with this on such an expensive blank. I'll handle that tomorrow. You can even see it in the photo just past the end of the neck pocket in the strat outline they drew:
I'm using a Mastery vibrato and bridge after reading about all the problems with OEM hardware. One of the things I like about the Jag is all the chrome, but unfortunately the Mastery is only available in brushed Stainless. Oh well. To match the vibrato, I ordered brushed stainless control plates from Faction Guitars. Price for these is a bit high for the quality IMO. The edges need to be eased and the countersinks aren't perfectly centered in the mounting holes. Still, they'll get the job done and match the rest of the hardware. You'll notice that the main control plate is blank - I'm not sure yet where I want to put the output jack, so I left it that way for now to keep options open as the build develops. There's also a decent chance that I won't like the pickup selector's location and decide to move it onto the main plate. I'll have to do a mockup to see if my right hand hits the switch. I'm going to do a 0.5 degree neck angle, so the bridge will be higher than on other Fenders. It's possible that the increased string height will make hitting the selector switch less of an issue.
I'm going with a 24.75" scale length rather than Fender's 24". Finish will be a burst of some sort, either traditional black/red/amber or something more like a dark sienna burst. I'm not a fan of faux tortoise shell pickguards, so it will be B/W/B.
