Are Thinline Semi-hollow Tele's Neck-heavy and Unbalanced
Discussion in 'Telecaster Discussion Forum' started by PCollen, Feb 19, 2018.
  1. PCollen
    PCollen Friend of Leo's
    Man of the World
    Are they ?
  2. Fuelish
    Fuelish Tele-Meister
    foothills of the Great Smoky Mountains, east TN
    Mine isn't ....overall, I was expecting the guitar itself to be a bit lighter, but I don't notice it being neck-heavy at all
  3. metalicaster
    metalicaster Tele-Afflicted
    I'm a wanderer...
    They do lean more than way, nowhere near as much of a problem as with say.. a Gibson SG
    I've had one that was, I put a Bigsby on it, problem solved.
  4. Wayne Alexander
    Wayne Alexander Friend of Leo's
    Los Angeles, CA, USA
    Mine is not
  5. imwjl
    imwjl Poster Extraordinaire
    My mom's basement.
    My only experience to compare is a Thinline after "52 AVRI", Highway One and a PRS Hollow Body. The Thinline balances better than the PRS Hollow Body did. If I move from my big SoCo 16 (kind of single cut ES-335 dimensions) to Thinline I notice scale, neck shape and fingerboard radius more than any balance.
    To me all that translates to no.
  6. 8barlouie
    8barlouie Friend of Leo's
    Southeast Massachusetts
    I had a 72 Tele Thinline. No problem.
  7. schmee
    schmee Poster Extraordinaire
    My ash TL with a fat strat neck was not neck heavy balanced.
  8. cyclopean
    cyclopean Friend of Leo's
    innsmouth, MA
    i thought the original ones were semi hollow because they were made of heavier wood?
  9. BorderRadio
    BorderRadio Poster Extraordinaire
    Phoenix, AZ
    5.8 lb '69 Thinline here, no balance issues.
    singlecoil, FenderLover and imwjl like this.
  10. charlie chitlin
    charlie chitlin Doctor of Teleocity
    Spring City, Pa
    Not mine.
    But it's got 3 humbuckers ;)
  11. Widerange Hum
    Widerange Hum Tele-Holic
    San Diego, CA
    Almost never. Weight savings is pretty minimal and the design of the tele body is such that neck dive is harder to induce than with an SG. I've had solid tele bodies that weighed only 3 pounds, had Warmoth necks with the heavy side-adjust double acting rod in them, and they still didn't neck dive.
  12. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    My '73 is 7 lb. 9 oz. with a big C neck. I would not complain about neck dive at all.
  13. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    If so, use a coiled cable and run it between your strap and strap lock. That'll fix any neck dive issues on any guitar. And a damn cheap fix too!
    My Thinlne Deluxe though...
    No dive.
  14. SonsOfMoog
    SonsOfMoog Tele-Meister
    US
    If you wear the guitar a little high, they tend to be neck heavy.
    As the guitar strap lowers the balance improves.
    Owenmoney likes this.
  15. ac15
    ac15 Poster Extraordinaire Ad Free Member
    CHICAGO, IL.
    Mine is fine. The weight skews a bit more to the neck side than some of my other guitars, but it's no big deal in practice, because my arm is resting on the body of the guitar for counter balance while playing it. I don't consider it a problem.
  16. Crobbins
    Crobbins Friend of Leo's Ad Free Member
    Meiners Oaks CA.
    I don't remember the thinline that I once owned ever being neck heavy.
    Lake Placid Blue likes this.
  17. Lake Placid Blue
    Lake Placid Blue Poster Extraordinaire
    California
    Nope
  18. INFANT
    INFANT Tele-Holic
    Stoney Creek, Ontario
    My '72 RI weighs in at 6lbs 3oz. When I first got it I felt a tiny bit of neck dive compared to my other tele. However, I now use a suede backed strap and it doesn't move at all. I also tend to wear mine a bit higher than most so that may account for it.
  19. ebb soul
    Smyrna georgia
  20. Garruchal
    Garruchal Tele-Meister
    Seattle
    Yes. My Squier CV thinline is neck-heavy. I moved the strap-pin and it solved the problem. It is an unusual solution, but it worked: neck-side strap pin on the back of the guitar on the horn. Works like a charm.
