Great thread. Thanks for so many good posts.
It would seem that the vast majority of solid state amps, especially from very reputable companies, are likely to be trouble free for the long haul. Unlike tube amps, where some maintenance is needed as there are tube issues that need tending to.
The rigors of being regularly/continuously gigged quite likely increase the likelihood of needing service or repairs. Perhaps this wear may well impact tubes pretty readily. Point to point wiring or hand wiring (larger solder connections?) may withstand heavy jarring better than fine/tiny traces on thin circuit boards? I have no idea about this.
The point someone made about the majority of bass amps being solid state, for many decades, and so reliable, is a good one. I think that says that there is probably little to worry about with regard to reliability, with solid state amps from good companies.
My solid state Yamaha THR10 has been stellar and flawless for well over a decade and I use it pretty much every day. Of course, it is not subjected to the rigors of being knocked around, handling, shipping, moving, gigging, etc. And it's so small and light weight. Knowing Yamaha, it will probably perform flawlessly for a great many years to come. The on/off switch may fail before anything else.
I do still have appreciation for tube amps and it's good that for the most part, they can be serviced/repaired if a component goes down. I haven't used a tube amp for quite a while, until acquiring this used Morgan MVP23 recently. It has really impressed me. I'm happy to be back in the tube world again, but won't be moving this amp around.
Both technologies are great, I think. I can certainly enjoy them both. But I can see that with some solid state amps, especially modelers, if a failure does occur well after warranty expiration, they may not be repairable or worth attempting a repair. And given their relatively low initial cost, that's not much worth worrying about.
