Are Black Baja Teles Heavier?
Discussion in 'Telecaster Discussion Forum' started by dscottyg, Mar 16, 2021.
  1. dscottyg
    dscottyg Tele-Meister
    Jacksonville
    I’m trying to get my hands on a black Classic Player Baja Telecaster. The two I have seen on eBay and Reverb or 9 pounds and 8.6 pounds. I would have but either one if they were lighter. Is it just a fluke?
    naranja66 likes this.
  2. qblue
    qblue Tele-Afflicted
    Clarks Summit, PA
    Well my blonde Baja weighs 8.8 lbs, from 2007. After 2010 Black and black sunburst models were available. If weight made a difference I would get a lighter one. But the pickup combination and the neck profile is what sold the world on the Baja model, and all of them are Ash.
    Good luck on finding one.
  3. takauya
    takauya Tele-Meister
    Forest
    Colors don't matter, just a lot of Bajas are ridiculously heavy.
    My black Baja was 3.5kg (7.7lbs), and my BSB is 3.3kg (7.3lbs).
    Fretting out and dscottyg like this.
  4. tele12
    tele12 Friend of Leo's
    NY
    I remember playing an early Baja that felt like it was made of concrete. Made 70s Les Paul's seem light by comparison.
    dscottyg likes this.
  5. Bedder18
    Bedder18 Tele-Meister
    Corydon Indiana
    My MIM 72 custom RI weighs a ton. Usually the 72 custom/deluxe bodies weigh a bit less because of the extensive routing, but not the MIM versions. They are sleds. My MIA version of the same guitar weighs in at about a pound lighter (unloaded body compared to unloaded body). Idk how the classic series compares but my experience has been that the Mexi bodies are weighty. But for what it’s worth, weight alone doesn’t make or break a guitar. One of best sounding guitars is nearly 9 pounds, so....
    Mast0rs and dscottyg like this.
  6. Flaneur
    Flaneur Poster Extraordinaire
    Scotland
    Yes, it's a fluke. I can't think of a commercial or manufacturing reason why they would do that. Painting all the ill-matched, or scratched-up bodies a solid colour, to disguise it? Probably. :)
    Bruxist and Danb541 like this.
  7. Tele22
    Tele22 Tele-Meister
    Europe
    My black Baja Tele weighed 4.1kg (9lbs) last time I checked. It's my heaviest guitar, but always sounds great.
  8. dannyh
    dannyh Tele-Afflicted
    North Texas
    I think that's just the norm with Baja's (heavy), IME anyway. The last Baja I had (BSB) weighed more than my LP. I've heard of lighter ones but never found one myself.
    Fretting out likes this.
  9. archetype
    archetype Fiend of Leo's
    Williamsville NY
    With the Baja 50s, some of the earlier ones were lightweight, most were average, some were heavy. Later ones were typically 7 1/2-8 1/2 pounds, some weighed as much as a dwarf star. My 2016 is 7 lb, 8 oz.
    The color has no correlation with any weight.
  10. Cosmic Cowboy
    Cosmic Cowboy Tele-Holic
    New Mexico
    Baja's are generally several piece bodies, using pieces of timbers not likely to be found in custom shop guitars. They are glued and these pieced and glued frankenbodies are radically inconsistant in wieght.
    This is not a diss on 4 or 5 piece bodies. I've played and owned some great ones. Generally the darker the paint, the more likely the wood is very unmatched. So there may be a bit of science to your question.
    qblue likes this.
  11. BluesGuitarMart
    BluesGuitarMart Tele-Meister
    Dublin, Ireland
    My 2016 BSB is 8.4lbs, doesn't feel too heavy to me.
  12. hemingway
    London, UK
    Mine's two pieces. Just sayin'. But yeah, still heavyish at over 8lbs. But to me heavy starts at 9 lbs.
    Cosmic Cowboy likes this.
  13. takauya
    Forest
    For most tele players 8lbs is already too heavy. I can't even imagine a 9lbs tele unless the body is white ash. They would sound killer with good amount of distortion. Jeff Beck's Tele-Gib was really heavy according to someone who hold it.
  14. wout
    wout TDPRI Member
    antwerp
    The answer is yes, black paint is heavier then white paint, so the same baja would be heavier in black then in white. That’s the reason most planes are white ;)
  15. ZenGuitarist
    ZenGuitarist Tele-Afflicted
    Alberta, Canada
    My black Baja weighs 8.8 lbs. so I probably own one of the heavier ones but that's the luck of the draw. I doubt the colour has any correlation with weight.
  16. archetype
    Williamsville NY
    Then I want a clear finish. ;)
  17. boris bubbanov
    New Orleans, LA + in the
    I do think that the folks in Ensenada used the better looking ash bodies for the BSB examples, for the most part and there is IMO a slight weight correlation between less than pretty and kinda hefty ash bodies.
    I've seen a fair number of Bajas, in the flesh (I bought seven after trying out at least 100 in person [mostly at numerous GCs]) and it did seem to me the BSBs were a bit lighter. But they were also full price or close to it and the real kicker was, the Desert Sand (or Black) ones tended to sound better as a group.
    I've got a chance to play these things, over a decade in a half, and I've come to the radical conclusion that, in general, my heaviest ones ("Pensacola" is almost 9 pounds) sound cooler. I didn't really expect that to happen. But there you have it. Sure it is anecdotal, but anecdote based on 7 examples is better than anecdote based on two or three.
    Personally, I don't think ash Bajas weigh any more on average than do ash Deluxe Nashvilles or ash 50s Classics. I believe that the "weight mania" peaked at the same time the CP Baja (50s) hit the market - this is why they got this reputation and also, folks looking for the best ones really did kinda go nuts there for a while. Had to be BSB, had to be under 8 pounds - everything else was avoided. Things went overboard, IMO.
    Mast0rs, BluesGuitarMart and Tele22 like this.
  18. Bedder18
    Corydon Indiana
    quality :lol:
  19. archetype
    Williamsville NY
    You've inadvertantlly remiinded me of the rolling, Baja 50s weight thread. I haven't seen an addition to it for a long time. You add a line that lists your Baja, year, weight, and anything that fits in one line, then post. The next person does the same for their Baja 50s, etc.
    Ok, I found it in the Baja Owners club. The last entry was in 2019, after which the Baja weight obsession died down and folks got obsessive about how much their Twin Reverbs weighed.
    https://www.tdpri.com/threads/baja-owners-club.131546/page-124
  20. Fuggle
    Fuggle Tele-Meister
    Georgia
    My 2019 blond Baja tips the scale at 8.6 lbs. This ties it for first place with my Firefly FFLP as my heaviest guitar. Not quite a boat anchor, but the weight is noticeable. I do use a wider strap with this one.
