Are Affinity Teles Routed for Humbuckers?
Discussion in 'Squier Tele Forum' started by guitarist232345, May 11, 2020.
  1. guitarist232345
    guitarist232345 Tele-Meister
    london
    Could I easily install humbuckers in an affinity tele by Squier?
    BBQedIguana likes this.
  2. jfgesquire
    jfgesquire Tele-Holic
    Lake View
    The neck position is, yes.
    Sent from my LG-H932 using Tapatalk
  3. jfgesquire
    Lake View
    I should clarify....
    If you check out eBay and the like, you see some older affinity top loader bodies had just a single coil neck rout.
    The new string through Affinities are humbucker neck rout.
  4. radiocaster
    europe
    Here's a photo of one from one thread:
    Here's one from another thread:
    The one on the bottom has a string through bridge, the one at the top has a top loader bridge. Not completely sure about what's under the bridge plate of the second, I found another picture of an alleged Affinity, but it was apparently mislabeled.
  5. Urshurak776
    Urshurak776 Tele-Holic
    Charlotte
    There's always SD Hot rails. You can pretend you're Dave Murray or Janick Gers (maybe older Adrian Smith.)
    LOL :)
    68Telebass likes this.
  6. radiocaster
    europe
  7. grzz51
    grzz51 TDPRI Member
    West Helena, AR
    My 2019 Affinity Tele is humbucker route in the neck and regular in the bridge. It is a string thru......
  8. guitarist232345
    london
    Urshurak776 and BBQedIguana like this.
  9. nicod98
    nicod98 Tele-Afflicted
    Belgium
    Just looking at eBay gives an answer to this... "it might"... there's no apparent link to year or colour.
  10. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    My 2017 has SC routes and is a top loader
  11. radiocaster
    europe
    With the newer ones you can't say, but I think the much older ones have that square with a small triangle at the top of it in the bridge position. Not sure it will fit a humbucker exactly, it might need some minimal work like a little bit of drilling for the screws. Or not.
    edit: actually check out the new one in this thread:
    https://www.tdpri.com/threads/2020-affinity-tele-total-obduction.1024053/
  12. Mr Gunny
    Mr Gunny Tele-Meister
    Wisconsin
    My 2019 is a top loader, neck is routed for a humbucker.
  13. 3-Chord-Genius
    Winchester, VA
    The neck position on my Affinity butterscotch blonde was not. I had to chisel the opening larger to fit a P90 in it.
  14. jfgesquire
    Lake View
    Serial number? Black plug in neck?
  15. jfgesquire
    Lake View
    Serial number? Year? Black plug in headstock? Country of origin?
  16. 3-Chord-Genius
    Winchester, VA
    It was made in China. Made a bunch of other mods to it as well (obviously).
  17. jfgesquire
    Lake View
    P90.... Oooh....
    That's one of the now "older" ones without the black plug in the headstock.
    What year is it?
    How did you do the wiring for the P90, anything fancy?
  18. Mr Gunny
    Wisconsin
    It’s an Indo, no black plug. ICS19008388
  19. jfgesquire
    Lake View
    Thank you.
    Yours is one of the last top loaders out of Indonesia, apparently, before the move to China.
    The other one posted is interesting. The owner said it was made in China but has Indonesian features.
    Serial numbers help try to figure out what Squier was doing.
  20. nicod98
    Belgium
    Ive seen these are current colours both with single coil and both with humbucker routing on eBay... but I've seen race red, the orange one, and the previous gun metal grays (2013-2016) with both routings too... I have no experience with pré 2013 Squier Affinity tele routings.
    If you want a humbucker at the bridge you'll have to take your router out of the shed too... ;-)
    It looks like the humbucker routing is combined with (I hope) conductive paint in the neck and control routing.
    race green: humbucker or single coil
    [​IMG][​IMG]
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=263386115788
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=254147458867
    slick silver: humbucker / single coil
    [​IMG][​IMG]
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=253618305172
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=253778330942
