AO-43 to 18 watt build (slowly)
Discussion in 'Shock Brother's DIY Amps' started by Jake Nelson, Nov 18, 2019.
Tags:
  1. Jake Nelson
    Jake Nelson Tele-Meister
    Bemidji, MN
    Last summer a friend of mine’s folks moved from their home into a old folks apartment and they didn’t have room for an organ so i said i would take it. The friend plays guitar so i thought i’d make a amp out of it because he has never played a tube amp and it will stay in the family.
    I had gutted it earlier and ordered a 18 watt tmb kit from Mojotone and today i started placement, found that the chassis is too narrow for a traditional 18 watt build so i moved the input jack to the back and cut at least a 1/4 inch off both sides of the turret board using a table saw. the board will be over the tube sockets a little bit still but it should be serviceable.
    i set it up so the master volume is last because i plan on doing a post phase inverter master volume.
    [​IMG] [​IMG]
  2. Jake Nelson
    Bemidji, MN
    I worked on some soldering yesterday and today. Got the board populated. I would say this is my second favorite part next to first fire up!
    Nice to have a cup of coffee nearby too.
  3. Mr Ridesglide
    Mr Ridesglide Tele-Afflicted Ad Free Member
    Bloomington, MN
    Nice!
  4. muscmp
    muscmp Tele-Afflicted
    california
    following.
    i have an ao43amp, ao42preamp, reverb pan, 2-12"heppner speakers and connectors from a 65 hammond L112 that i still need to piece together
    play music!
    Jake Nelson likes this.
  5. Jake Nelson
    Bemidji, MN
    Moved some cows, ate some pie, soldered some heater wires. All in all a good turkey day.
  6. Digital Larry
    Digital Larry Tele-Afflicted
    Silicon Valley, CA
    That's cool. I've had an AO-43 laying around for years. I think I decided it's one of those things I'm not going to do. But it's nice to see people are still getting some mileage out of it! I thought about how to try to rig it up without completely redoing the insides and as you seem to be proving, it's not quite possible.
