Anyone used 0000 steel wool for fret polishing ?
Discussion in 'Finely Finished' started by AJ Ray, Apr 8, 2020.
  1. AJ Ray
    AJ Ray Tele-Meister
    dundee
    With so many people against steel wool and the damage it does to pickups. I wonder what you guys have done ? I figure if I mask the pickups and go over the guitar afterwards with a magnet i should remove any small pieces which have came loose?
    DrPepper likes this.
  2. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Yep. I do. Just as you described, for the last 35+ years. Be sure and mask the fretboard, too; especially glossy finishes.
  3. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    Steel wool is exactly what I use. I just tape over the pickups (and a little bit around; my goal is to cover any area the steel wool bits may stick to), and when I'm done I tape over those same areas again and pull off the whole tape-steel wool-tape sandwich in one go and toss it.
    DrPepper, ElJay370 and JuneauMike like this.
  4. Dismalhead
    Sacramento, California
    I've done it with steel wool, and IMO it's just not worth it. Files and sandpaper are how I deal with my frets. You could turn it around and say "What's so special about steel wool that you can't do with files and sandpaper?" too.
    8barlouie and Bendyha like this.
  5. schmee
    I dont find it that helpful even overlooking the iron dust. 600 grit wet dry works great. I use it with WD40 to ake ridges from flattening or the like off.
    If I just want smooth shine then a Dremel cotton wheel with a polish like 3M Finesse-It will make a fret shine like a mirror in 5-10 seconds each.
    guitarmikey, 8barlouie and wrvond like this.
  6. JuneauMike
    Alaska
    Yeah, it works great. Regardless of what you use, anytime you are taking material off the frets you should tape over the pickups.
    But with steel wool, I buy a few of those asprin shaped earth magnets from the hardware store and wrap the steel wool around them. Works great at keeping the steel splinters down.
    rand z and E5RSY like this.
  7. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    are you guys kidding? do you actually tape off all the pickups and everything? Man, you all have a lot more time to waste that I ever did.
    Rubbing compound - the red stuff. A rag. 10 minutes. Done.
  8. JuneauMike
    Alaska
    Someone else can swoop in with some facts here, but I don't think its a good idea to touch a pickup with something magnetic. Hmm, anyone else?
    vid1900 likes this.
  9. Wally
    If it is bolt-on neck, take the neck off. If it is a set neck or neck through, then I usually have at least the neck pickup out of the mounting hole and taped back by the bridge...away from any harm....maybe bagged up and with the bridge p-up taped off. This is because usually if I am polishing frets I will leveling with a file, then using radopius block/s, then sanding, and finally using 0000 wool for polishing. So, the pickup needs to be out of the way of the file and the radiusing block.
    IF for OEM reason I am using 0000 without removing the pickup, then I mask the pickup off very well. Before removing that tape, I use another piece of tape to pull whatever pieces of 0000 have been attracted to the magnets...they Are plainly visible on top of the tape. No problems in 30 years......and glass like fret tops that bend like a dream.
    SamIV, E5RSY and JuneauMike like this.
  10. matmosphere
    matmosphere Tele-Afflicted
    earth
    Wally likes this.
  11. Peegoo
    Peegoo Friend of Leo's
    Fret material is non magnetic--even stainless steel fret wire--so no need to tape over the pickups when doing fret work unless you are using steel wool.
    I use steel wool to polish frets and clean non-finished fretboards, and I tape a sheet of printer paper or newspaper over the face of the guitar.
    If you do get metal particles on the polepieces, you can use duct tape or chewing gum (chew it up first haha) to remove the particles.
  12. E5RSY
    Georgetown, TX
    Dude, that's so RADOPIUS!
    Wally likes this.
  13. DADGAD
    DADGAD Friend of Leo's
    Earth
    Put blue painters tape over the pickups before using 0000 steel wool on the frets. Afterwards, put another layer of blue tape over any shavings that stuck to the blue tape above the pickups, trapping the shavings. Pedal it off and throw it away when done.
    vid1900 likes this.
  14. Freeman Keller
    I use steel wool and micro mesh to polish all my fret work. I avoid polishing compound and dremel - too easy to burn thru binding and damage the f/b itself. I do mask pickups if I'm working on an electric guitar and I also mask around the head and body anytime I'm working on frets.
    telemnemonics likes this.
  15. darkwaters
    darkwaters Tele-Afflicted
    Newfoundland
    I use the white Scotchbrite pads. They're gentler than the green ones.
    8trackmind likes this.
  16. Wally
    E5RSY...I’ll leave my IPad Air’s spell correction there so that your post works for the comedic relief we all need!! thanks for the chuckle!!!!
  17. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    I have no idea why you would use steel wool when micromesh does the job better and does not create problems. Wet-or-dry paper in superfine grits works, too. (I start at 800 and go to 3,000 to 5,000.) Micromesh and paper come finer than steel wool.
    matmosphere and kingofdogs1950 like this.
  18. E5RSY
    Georgetown, TX
    To add to the comedy, I was actually compelled to try to look it up initially. I thought I was gonna learn a new word from you. :lol:
  19. SithTracy
    SithTracy TDPRI Member
    S.E. Wisconsin
    Tape off pickups with painters tape and use 0000 steel wool... I also have a magnet I run around the guitar to make sure I get any straggler pieces of steel wool before removing the tape to prevent any little pieces from finding their way in later.
  20. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    I use steel wool as the second to last step. I use a high-quality metal polish as the last step.
    Steel wool doesn’t really damage pickups IME. It’s just an annoyance sometimes because the magnets collect the dust, if you leave the pickups uncovered.
    IME, don’t be an impatient slob in the way you work, and you won’t have any problems with steel wool. I’ve only had problems with it when being an impatient slob. And even then, all it takes is some compressed air to blow it off of the magnets.
    All this being said, there are many things you can use to polish frets well. It’s not like only one method will give good results. Scotch-Brite is fine. Emery paper can be fine. Etc. I use steel wool because I’m familiar with it, I always have it on hand anyhow, it’s classic, it works, it’s available everywhere, and it is as cheap as dirt.
